Hello.
Is their a way to remove the default editor components? Specifically “code block”.
Adding I’ve gotten the hang off, but not removing default.
Can’t find anything in the docs that address this.
Thanks!
hi there rogelio, can you say a little more why you’d like to remove it? generally people seem to think it’s a really useful feature, so i want to make sure i understand your use case. thanks!
The markdown widget takes a buttons
parameter, with which you can set the options for the editor components bar:
Hello, Customizing templates for specific use cases.
Thanks Tom, That makes sense, I’ll try later this evening. Thanks again.
With the slight detail that it was editor_components.
Thanks much!
