Home
Support Forums
Provisioning certificate for site "elegant-mahavira-2b8a0b" is taking more than 24 hours
Provisioning certificate for site “elegant-mahavira-2b8a0b” is taking more than 24 hours
Hi @dacha_dallocort
As a netlify.app subdomain elegant-mahavira-2b8a0b automatically has SSL. You are talking about a custom you are trying to use? What is the custom domain?
The custom domain is: pametnoknjigovodstvo.com
The solution is:
Remove the following AAAA record:
and add a CNAME record for the ww subdomain pointing to elegant-mahavira-2b8a0b.netlify.app.
Big thanks. That is it, solved. One question, why AAAA record has to be removed?
It’s because Netlify doesn’t (yet) support IPv6 (AAAA) records when using external DNS.
