looks like your build is failing as we couldn’t find the package.json file we need to know how to built your project and which dependencies it needs:
7:19:22 AM: $ CI= npm run build
7:19:23 AM: npm ERR! code ENOENT
7:19:23 AM: npm ERR! syscall open
7:19:23 AM: npm ERR! path /opt/build/repo/package.json
7:19:23 AM: npm ERR! errno -2
7:19:23 AM: npm ERR! enoent ENOENT: no such file or directory, open '/opt/build/repo/package.json'
7:19:23 AM: npm ERR! enoent This is related to npm not being able to find a file.
7:19:23 AM: npm ERR! A complete log of this run can be found in:
7:19:23 AM: npm ERR! /opt/buildhome/.npm/_logs/2022-05-10T14_19_23_194Z-debug-0.log
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem Additionally, this Support Guide houses all of our resources for debugging build and deploy issues.
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide as much information as you can on what you have already tried, what your build settings are, your package.json, etc. Thanks!
