Problema de Building no sistema web
Por favor alguem conseguem me ajudar a resolver o problema que acorre no meu sistema web
https://deploy-preview-123--elliotfinance.netlify.app
branch-name–elliotfinance.netlify.app
7:05:01 PM: Netlify Build
7:05:01 PM: ────────────────────────────────────────────────────────────────
7:05:01 PM: ​
7:05:01 PM: ❯ Version
7:05:01 PM: @netlify/build 29.58.1
7:05:01 PM: ​
7:05:01 PM: ❯ Flags
7:05:01 PM: accountId: 676888c162c05512e4c6cdd1
7:05:01 PM: baseRelDir: true
7:05:01 PM: buildId: 67688ce6218ce21788f9bb67
7:05:01 PM: deployId: 67688ce6218ce21788f9bb69
7:05:01 PM: ​
7:05:01 PM: ❯ Current directory
7:05:01 PM: /opt/build/repo
7:05:01 PM: ​
7:05:01 PM: ❯ Config file
7:05:01 PM: No config file was defined: using default values.
7:05:01 PM: ​
7:05:01 PM: ❯ Context
7:05:01 PM: production
7:05:01 PM: ​
7:05:01 PM: Build command from Netlify app
7:05:01 PM: ​
7:05:01 PM: $ npm run build
7:05:01 PM: > build
7:05:01 PM: > vite build
7:05:01 PM: vite v5.4.11 building for production…
7:05:01 PM: transforming…
7:05:01 PM: ✓ 2 modules transformed.
7:05:01 PM: x Build failed in 177ms
7:05:01 PM: error during build:
7:05:01 PM: [vite]: Rollup failed to resolve import “/src/main.jsx” from “/opt/build/repo/index.html”.
7:05:01 PM: This is most likely unintended because it can break your application at runtime.
7:05:01 PM: If you do want to externalize this module explicitly add it to
7:05:01 PM: build.rollupOptions.external
7:05:01 PM: at viteWarn (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CB_7IfJ-.js:65589:17)
7:05:01 PM: at onwarn (file:///opt/build/repo/node_modules/@vitejs/plugin-react/dist/index.mjs:282:9)
7:05:01 PM: at onRollupWarning (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CB_7IfJ-.js:65619:5)
7:05:01 PM: at onwarn (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CB_7IfJ-.js:65284:7)
7:05:01 PM: at file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:19537:13
7:05:01 PM: at Object.logger [as onLog] (file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:21263:9)
7:05:01 PM: at ModuleLoader.handleInvalidResolvedId (file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:20152:26)
7:05:01 PM: at file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:20110:26
7:05:01 PM: ​
7:05:01 PM: “build.command” failed
7:05:01 PM: ​
7:05:01 PM: Error message
7:05:01 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
7:05:01 PM: ​
7:05:01 PM: Error location
7:05:01 PM: In Build command from Netlify app:
7:05:01 PM: npm run build
7:05:01 PM: ​
7:05:01 PM: Resolved config
7:05:01 PM: build:
7:05:01 PM: command: npm run build
7:05:01 PM: commandOrigin: ui
7:05:01 PM: publish: /opt/build/repo/dist
7:05:01 PM: publishOrigin: ui
7:05:02 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
7:05:02 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
7:05:02 PM: Failing build: Failed to build site
7:05:02 PM: Finished processing build request in 28.969s
Does your repository contain a /src/main.jsx file?
Nao! Eu criei o sistema com a ajuda de uma IA, bolt.new
E acho que a ia nao criou esse diretorio.
@tiagobecker If you made it with bolt.new you should get your support from bolt.new
Your issue isn’t with Netlify and I’m not going to be able to provide non-developer assistance
