hello everyone, I’m trying to convert a html template to react but my sliders doesn’t seem to load properly.
your help will be appreciated.
my repo: GitHub - yusuf-ishan/react
Hi @Yusuf, in order for your slider to work you need to add the JavaScript plugin that was used in the HTML template which enables the slider or other functionality.
There are 3 solutions to add all the JavaScript scripts from the template
Add your JavaScript script tags to your index.html file located at public / index.html
Use a plugin called Helmet which manages
script
andlink
tags within the<head>
tag -
Adding scripts by using the React hook
useEffect
Kindly read the blog post below on how to add scripts in a React application.
Thanks.
I added the JavaScript script tags but it’s not working.
Hi @Yusuf, thanks for the feedback.
I don’t see the JavaScript script tags added anywhere in the GitHub repository you shared.
If possible can you share a code snippet of your code where you added the script tags or point me to the file where you added the script tags?
Thanks.
sorry I forgot to push the new changes, you can now see the script tags in index.html in my repo
fixed it with react helmet, thanks for the help!!
Hi @Yusuf, thanks for letting me know my suggestion helped. Glad to know your problem has been resolved.
