Problem with Netlify Certificate -- can't renew it -- failed verification
My domain stevesloper.com is stuck in a failed verification state.
DNS is correct (both required A records are present), and I removed and re‑added the domain, but the HTTPS panel still only shows the DNS setup links and no certificate buttons.
The site now shows “Secure Connection Failed” because the certificate is out of sync across Netlify’s edge nodes.
Could a staff member please clear the domain verification state on your end so the certificate can be re‑issued?
Hey @Steves :wave:,
Thanks for reaching out!
We’ve gone ahead and created a support ticket for you, so our team can follow up with you directly via email from the help desk. Our Support crew will be in touch with you by email soon.
Great news: these days anyone can reach out to Netlify Support. First, you can try getting an answer using Ask Netlify, our helpful AI search tool. If your question isn’t answered there, you can submit a ticket using the support form, and we’ll take it from there.
We’re keeping the community around for swapping ideas, sharing tips and tricks, and talking shop with other folks building on the platform — but for support issues, tickets are the way to go.
Thanks for being here, and keep an eye out for that email from us!
