Problem with my own domain
When i try to enter to my domain (devcristian.com.ar) i had an time out connection error. what can be happen?
Hi @galacticgamingmmb,
Thanks for reaching out!
Visiting www.devcristian.com.ar, is working for me. Were you able to resolve the issue?
I do see that the Netlify name servers are correctly configured and the SSL Certificate has been provisioned.
If you’re still having issues, are you only seeing the connection error when visiting the site from your ISP or computer or are you seeing this issue on multiple networks?
yes. is now working! I just had to wait a little bit :smiley:
