Netlify site name: chessecho.netlify.app
I have got a domain from namecheap (chessecho.com ), I followed this guide which guides through using Netlify DNS addresses as custom DNS on namecheap.
I thought it might take some time for DNS configuration to take effect but after about an hour, I don’t think it’s the case, I also tried redeploying after reading one of the forum subjects.
Any help appreciated, Thanks
dig
December 26, 2023, 12:05am
2
I see nothing wrong with the DNS configuration @nabilrise and am able to access both chessecho.com
and www.chessecho.com
What issue are you experiencing?
Strange, now it’s working for me too.
But right before I posted the output of the dig command was
And now It is:
; <<>> DiG 9.16.1-Ubuntu <<>> chessecho.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22334
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;chessecho.com . IN A
;; ANSWER SECTION:
chessecho.com . 20 IN A 3.70.101.28
chessecho.com . 20 IN A 35.156.224.161
;; Query time: 60 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Tue Dec 26 01:20:17 CET 2023
;; MSG SIZE rcvd: 74
Now it’s working just fine, but do you happen to know what was the issue before?
dig
December 26, 2023, 12:49am
4
As shown in the screenshot, the TTL at that point was 1182—just under twenty minutes. So likely the previous DNS records came from a cache on your computer, network, or DNS provider when then expired at that point.
Got it. Thanks for taking the time.
