Hi!
I am having a problem with my getLotofacilContests
schedule function.
For some time, it worked perfectly, but nowadays, it starts to return errors.
The error is that I am receiving a 401 or 403 from the CAIXA website link.
But if I run the code on my local machine, it works perfectly!
Can you help me make the function work properly again? It is hard to make it run every day on my local machine.
My website:
https://lotoproweb.com.br/
Page for which I took the URL:
https://loterias.caixa.gov.br/Paginas/Lotofacil.aspx
The request that I need to access every day is:
curl 'https://servicebus2.caixa.gov.br/portaldeloterias/api/lotofacil/3131' \
-H 'accept: application/json, text/plain, */*' \
-H 'accept-language: pt-BR,pt;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6' \
-H 'origin: https://loterias.caixa.gov.br' \
-H 'priority: u=1, i' \
-H 'referer: https://loterias.caixa.gov.br/' \
-H 'sec-ch-ua: "Not/A)Brand";v="8", "Chromium";v="126", "Microsoft Edge";v="126"' \
-H 'sec-ch-ua-mobile: ?0' \
-H 'sec-ch-ua-platform: "Windows"' \
-H 'sec-fetch-dest: empty' \
-H 'sec-fetch-mode: cors' \
-H 'sec-fetch-site: same-site' \
-H 'user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36 Edg/126.0.0.0'
Error logs:
Jun 18, 10:00:17 PM: 811dea1f 8.42079 0.5 8.27027 0.5C8.11974 0.5 7.97538 0.559797 7.86894 0.666237C7.7625 0.772676 7.7027 0.917039 7.7027 1.06757V2.01351H4.29729V1.06757C4.29729 0.917039 4.2375 0.772676 4.13106 0.666237C4.02462 0.559797 3.88025 0.5 3.72973 0.5C3.5792 0.5 3.43484 0.559797 3.3284 0.666237C3.22196 0.772676 3.16216 0.917039 3.16216 1.06757V2.01351H2.21621C1.66428 2.01351 1.13494 2.23277 0.744666 2.62305C0.354388 3.01333 0.135132 3.54266 0.135132 4.09459V12.4189C0.135132 12.9709 0.354388 13.5002 0.744666 13.8905C1.13494 14.2807 1.66428 14.5 2.21621 14.5H9.78378C10.3357 14.5 10.865 14.2807 11.2553 13.8905C11.6456 13.5002 11.8649 12.9709 11.8649 12.4189V4.09459C11.8649 3.54266 11.6456 3.01333 11.2553 2.62305C10.865 2.23277 10.3357 2.01351 9.78378 2.01351ZM2.21621 3.14865H3.16216V4.09459C3.16216 4.24512 3.22196 4.38949 3.3284 4.49593C3.43484 4.60237 3.5792 4.66216 3.72973 4.66216C3.88025 4.66216 4.02462 4.60237 4.13106 4.49593C4.2375 4.38949 4.29729 4.24512 4.29729 4.09459V3.14865H7.7027V4.09459C7.7027 4.24512 7.7625 4.38949 7.86894 4.49593C7.97538 4.60237 8.11974 4.66216 8.27027 4.66216C8.42079 4.66216 8.56516 4.60237 8.6716 4.49593C8.77804 4.38949 8.83783 4.24512 8.83783 4.09459V3.14865H9.78378C10.0347 3.14865 10.2753 3.24831 10.4527 3.42571C10.6301 3.60311 10.7297 3.84371 10.7297 4.09459V6.17568H1.27027V4.09459C1.27027 3.84371 1.36993 3.60311 1.54733 3.42571C1.72473 3.24831 1.96533 3.14865 2.21621 3.14865ZM9.78378 13.3649H2.21621C1.96533 13.3649 1.72473 13.2652 1.54733 13.0878C1.36993 12.9104 1.27027 12.6698 1.27027 12.4189V7.31081H10.7297V12.4189C10.7297 12.6698 10.6301 12.9104 10.4527 13.0878C10.2753 13.2652 10.0347 13.3649 9.78378 13.3649Z" fill="#F4F4F4"/> </svg> <span class="card-details__value"> 2024-06-19 01:00:18 </span> </p><hr/> <p class="card-details__row"> <span class="card-details__label">Request ID</span> <span class="card-details__value">1d75debb0dd145d96d4bdfae808ad79f-1f117607</span> </p><p class="card-details__row"> <span class="card-details__label">Status Code</span> <span class="card-details__value">403</span> </p><p class="card-details__row"> <span class="card-details__label">POP</span> <span class="card-details__value">EQN</span> </p></div></main> <footer> <svg width="80px" height="20px" viewBox="0 0 120 24" fill="none" xmlns="http://www.w3.org/2000/svg" class="h-[26px]" > <path fill-rule="evenodd" clip-rule="evenodd" d="M68.8751 0L64.3906 23.4146H87.711L92.1955 0H68.8751ZM72.5179 4.42392H86.8522L84.0623 18.9907H69.728L72.5179 4.42392Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M60.0001 0L55.6094 23.4146H59.9992L64.3899 0H60.0001Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M24.3824 0L0.654522 19.9761L0 23.4146H3.41853L21.7987 7.94855L18.8361 23.4146H23.3197L27.8049 0H24.3824Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M115.516 0L113.526 10.3871L117.148 14.8895L120 0H115.516ZM96.6798 0L92.1953 23.4146H96.6815L99.755 7.36298L112.711 23.4146H115.516L116.069 20.5482L99.4841 0H96.6798Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M32.2893 0L31.4419 4.42401H46.9283L28.4682 19.9674L27.8047 23.4146H51.125L51.9724 18.9906H36.4861L54.9502 3.44385L55.6096 0H32.2893Z" fill="#F3652B" ></path> </svg> <div class="footer__text"> © Azion Technologies, Inc or its affiliates. All rights reserved. </div></footer> </div></body></html>
Jun 18, 10:00:17 PM: 811dea1f ERROR Invoke Error {"errorType":"SyntaxError","errorMessage":"Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON","stack":["SyntaxError: Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON"," at JSON.parse (<anonymous>)"," at Runtime.handler (/var/task/netlify/functions/getLotofacilContests.js:66:26)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"]}
Jun 18, 10:00:18 PM: 811dea1f Duration: 798.74 ms Memory Usage: 118 MB Init Duration: 519.91 ms
Jun 18, 10:00:19 PM: 9ffae77f 0.666237C8.56516 0.559797 8.42079 0.5 8.27027 0.5C8.11974 0.5 7.97538 0.559797 7.86894 0.666237C7.7625 0.772676 7.7027 0.917039 7.7027 1.06757V2.01351H4.29729V1.06757C4.29729 0.917039 4.2375 0.772676 4.13106 0.666237C4.02462 0.559797 3.88025 0.5 3.72973 0.5C3.5792 0.5 3.43484 0.559797 3.3284 0.666237C3.22196 0.772676 3.16216 0.917039 3.16216 1.06757V2.01351H2.21621C1.66428 2.01351 1.13494 2.23277 0.744666 2.62305C0.354388 3.01333 0.135132 3.54266 0.135132 4.09459V12.4189C0.135132 12.9709 0.354388 13.5002 0.744666 13.8905C1.13494 14.2807 1.66428 14.5 2.21621 14.5H9.78378C10.3357 14.5 10.865 14.2807 11.2553 13.8905C11.6456 13.5002 11.8649 12.9709 11.8649 12.4189V4.09459C11.8649 3.54266 11.6456 3.01333 11.2553 2.62305C10.865 2.23277 10.3357 2.01351 9.78378 2.01351ZM2.21621 3.14865H3.16216V4.09459C3.16216 4.24512 3.22196 4.38949 3.3284 4.49593C3.43484 4.60237 3.5792 4.66216 3.72973 4.66216C3.88025 4.66216 4.02462 4.60237 4.13106 4.49593C4.2375 4.38949 4.29729 4.24512 4.29729 4.09459V3.14865H7.7027V4.09459C7.7027 4.24512 7.7625 4.38949 7.86894 4.49593C7.97538 4.60237 8.11974 4.66216 8.27027 4.66216C8.42079 4.66216 8.56516 4.60237 8.6716 4.49593C8.77804 4.38949 8.83783 4.24512 8.83783 4.09459V3.14865H9.78378C10.0347 3.14865 10.2753 3.24831 10.4527 3.42571C10.6301 3.60311 10.7297 3.84371 10.7297 4.09459V6.17568H1.27027V4.09459C1.27027 3.84371 1.36993 3.60311 1.54733 3.42571C1.72473 3.24831 1.96533 3.14865 2.21621 3.14865ZM9.78378 13.3649H2.21621C1.96533 13.3649 1.72473 13.2652 1.54733 13.0878C1.36993 12.9104 1.27027 12.6698 1.27027 12.4189V7.31081H10.7297V12.4189C10.7297 12.6698 10.6301 12.9104 10.4527 13.0878C10.2753 13.2652 10.0347 13.3649 9.78378 13.3649Z" fill="#F4F4F4"/> </svg> <span class="card-details__value"> 2024-06-19 01:00:19 </span> </p><hr/> <p class="card-details__row"> <span class="card-details__label">Request ID</span> <span class="card-details__value">d9c425602b081c7a711e15980e338c83-1f117607</span> </p><p class="card-details__row"> <span class="card-details__label">Status Code</span> <span class="card-details__value">403</span> </p><p class="card-details__row"> <span class="card-details__label">POP</span> <span class="card-details__value">EQN</span> </p></div></main> <footer> <svg width="80px" height="20px" viewBox="0 0 120 24" fill="none" xmlns="http://www.w3.org/2000/svg" class="h-[26px]" > <path fill-rule="evenodd" clip-rule="evenodd" d="M68.8751 0L64.3906 23.4146H87.711L92.1955 0H68.8751ZM72.5179 4.42392H86.8522L84.0623 18.9907H69.728L72.5179 4.42392Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M60.0001 0L55.6094 23.4146H59.9992L64.3899 0H60.0001Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M24.3824 0L0.654522 19.9761L0 23.4146H3.41853L21.7987 7.94855L18.8361 23.4146H23.3197L27.8049 0H24.3824Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M115.516 0L113.526 10.3871L117.148 14.8895L120 0H115.516ZM96.6798 0L92.1953 23.4146H96.6815L99.755 7.36298L112.711 23.4146H115.516L116.069 20.5482L99.4841 0H96.6798Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M32.2893 0L31.4419 4.42401H46.9283L28.4682 19.9674L27.8047 23.4146H51.125L51.9724 18.9906H36.4861L54.9502 3.44385L55.6096 0H32.2893Z" fill="#F3652B" ></path> </svg> <div class="footer__text"> © Azion Technologies, Inc or its affiliates. All rights reserved. </div></footer> </div></body></html>
Jun 18, 10:00:19 PM: 9ffae77f ERROR Invoke Error {"errorType":"SyntaxError","errorMessage":"Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON","stack":["SyntaxError: Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON"," at JSON.parse (<anonymous>)"," at Runtime.handler (/var/task/netlify/functions/getLotofacilContests.js:66:26)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"]}
Jun 18, 10:00:20 PM: 9ffae77f Duration: 352.09 ms Memory Usage: 133 MB
Jun 18, 10:00:21 PM: e730239d 0.666237C8.56516 0.559797 8.42079 0.5 8.27027 0.5C8.11974 0.5 7.97538 0.559797 7.86894 0.666237C7.7625 0.772676 7.7027 0.917039 7.7027 1.06757V2.01351H4.29729V1.06757C4.29729 0.917039 4.2375 0.772676 4.13106 0.666237C4.02462 0.559797 3.88025 0.5 3.72973 0.5C3.5792 0.5 3.43484 0.559797 3.3284 0.666237C3.22196 0.772676 3.16216 0.917039 3.16216 1.06757V2.01351H2.21621C1.66428 2.01351 1.13494 2.23277 0.744666 2.62305C0.354388 3.01333 0.135132 3.54266 0.135132 4.09459V12.4189C0.135132 12.9709 0.354388 13.5002 0.744666 13.8905C1.13494 14.2807 1.66428 14.5 2.21621 14.5H9.78378C10.3357 14.5 10.865 14.2807 11.2553 13.8905C11.6456 13.5002 11.8649 12.9709 11.8649 12.4189V4.09459C11.8649 3.54266 11.6456 3.01333 11.2553 2.62305C10.865 2.23277 10.3357 2.01351 9.78378 2.01351ZM2.21621 3.14865H3.16216V4.09459C3.16216 4.24512 3.22196 4.38949 3.3284 4.49593C3.43484 4.60237 3.5792 4.66216 3.72973 4.66216C3.88025 4.66216 4.02462 4.60237 4.13106 4.49593C4.2375 4.38949 4.29729 4.24512 4.29729 4.09459V3.14865H7.7027V4.09459C7.7027 4.24512 7.7625 4.38949 7.86894 4.49593C7.97538 4.60237 8.11974 4.66216 8.27027 4.66216C8.42079 4.66216 8.56516 4.60237 8.6716 4.49593C8.77804 4.38949 8.83783 4.24512 8.83783 4.09459V3.14865H9.78378C10.0347 3.14865 10.2753 3.24831 10.4527 3.42571C10.6301 3.60311 10.7297 3.84371 10.7297 4.09459V6.17568H1.27027V4.09459C1.27027 3.84371 1.36993 3.60311 1.54733 3.42571C1.72473 3.24831 1.96533 3.14865 2.21621 3.14865ZM9.78378 13.3649H2.21621C1.96533 13.3649 1.72473 13.2652 1.54733 13.0878C1.36993 12.9104 1.27027 12.6698 1.27027 12.4189V7.31081H10.7297V12.4189C10.7297 12.6698 10.6301 12.9104 10.4527 13.0878C10.2753 13.2652 10.0347 13.3649 9.78378 13.3649Z" fill="#F4F4F4"/> </svg> <span class="card-details__value"> 2024-06-19 01:00:21 </span> </p><hr/> <p class="card-details__row"> <span class="card-details__label">Request ID</span> <span class="card-details__value">159ecd1a272b524cfbf2a9bb03b47b74-1f117607</span> </p><p class="card-details__row"> <span class="card-details__label">Status Code</span> <span class="card-details__value">403</span> </p><p class="card-details__row"> <span class="card-details__label">POP</span> <span class="card-details__value">EQN</span> </p></div></main> <footer> <svg width="80px" height="20px" viewBox="0 0 120 24" fill="none" xmlns="http://www.w3.org/2000/svg" class="h-[26px]" > <path fill-rule="evenodd" clip-rule="evenodd" d="M68.8751 0L64.3906 23.4146H87.711L92.1955 0H68.8751ZM72.5179 4.42392H86.8522L84.0623 18.9907H69.728L72.5179 4.42392Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M60.0001 0L55.6094 23.4146H59.9992L64.3899 0H60.0001Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M24.3824 0L0.654522 19.9761L0 23.4146H3.41853L21.7987 7.94855L18.8361 23.4146H23.3197L27.8049 0H24.3824Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M115.516 0L113.526 10.3871L117.148 14.8895L120 0H115.516ZM96.6798 0L92.1953 23.4146H96.6815L99.755 7.36298L112.711 23.4146H115.516L116.069 20.5482L99.4841 0H96.6798Z" fill="#F3652B" ></path> <path fill-rule="evenodd" clip-rule="evenodd" d="M32.2893 0L31.4419 4.42401H46.9283L28.4682 19.9674L27.8047 23.4146H51.125L51.9724 18.9906H36.4861L54.9502 3.44385L55.6096 0H32.2893Z" fill="#F3652B" ></path> </svg> <div class="footer__text"> © Azion Technologies, Inc or its affiliates. All rights reserved. </div></footer> </div></body></html>
Jun 18, 10:00:21 PM: e730239d ERROR Invoke Error {"errorType":"SyntaxError","errorMessage":"Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON","stack":["SyntaxError: Unexpected token '<', \"<!DOCTYPE \"... is not valid JSON"," at JSON.parse (<anonymous>)"," at Runtime.handler (/var/task/netlify/functions/getLotofacilContests.js:66:26)"," at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"]}
Jun 18, 10:00:21 PM: e730239d Duration: 238.97 ms Memory Usage: 138 MB
