Home
Support Forums
Problem with api
hello dear
after deploying react to netlify I have problem when send post request in netlify website give me this error
POST https://hershcompany.com/api/v1/request/addRequest 404 (Not Found)
get methods is work perfect but only post and put is not work also no problem when I test in postman
Note : my API is hosted in vps ubunutu.
Hi @mohamednazm-web
Welcome to the forums.
Can you provide the URL of your website?
Edit:
Doesn’t appear as though this is a Netlify-specific issue. Not found is returned in the browser too
sir my url is post method but you try the get request so that is happen
I tried posting to the URL too
curl -X POST
     -d '{data: "something"}'
     'https://hershcompany.com/api/v1/request/addRequest'
Not found was returned again.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Not Found</pre>
</body>
</html>
If you can provide the URL of your Netlify site, and how you are making this call (I assume you are calling directly and not via a proxy) this may help provide you further assistance.
im sorry for late response
this is my all configuration
_redirects
/api/* https://hershcompany.com/:splat 200
/* /index.html 200
_headers
Access-Control-Allow-Origin: *
package.json
“proxy”: “https://hershcompany.com”,
when I convert to localhost and then try it all of this is work but after deploying in netlify is not work
also i call in here only get method i mean retrive data is work
import axios from “axios”
// const baseUrl = “http://localhost:4000
const baseUrl = “https://hershcompany.com
const API = axios.create({
baseURL: baseUrl,
export { API }
Can share the URL for the Netlify site you are calling the API from?
Thank you I solved :relieved: thank you for your information :pray:
