Problem run application
Hello, I have uploaded an application, https://group-organizer-suite.netlify.app, currently it gives an error but if I run it with the production deployment https://66dd8b6eaa07a9e59b6f1250--group-organizer-suite.netlify.app/ it does work, until yesterday it worked, after this last update it doesn’t. Thank you very much. NOTE: I just changed the name of the app and it worked, I put the old one back and no, do you know what it could be, currently the url is https://go-suite.netlify.app thank you very much for your help
The link you sent doesn’t exist anymore.
I’m sorry, I just changed the name of the app and it worked, I put the old one back and no, do you know what it could be, currently the url is https://go-suite.netlify.app thank you very much for your help
What’s the error you’re getting? Your app seems to be working.
