Problem Adding Custom Domain - Another site is already using
The domain has been removed from the other site.
I’m having some issue changing subdomain on our netlify for ohif.org, it says Another site is already using it. No matter what subdomain I say it doesn’t like it, I even tried adding random numbers and it still thinks someone has it. What is going on?
These are the subdomains I need to get released for me
demo.ohif.org
viewer-v2-legacy.ohif.org
viewer.ohif.org
viewer-dev.ohif.org
viewer-prod.ohif.org
ui.ohif.org
docs.ohif.org
Thanks
Hi @sedghi :wave:t6: , welcome to the forums! Thanks for reaching out. This is happening because the custom domain you’re trying to use already exists on Netlify under a different account.
Please verify domain ownership and let us know by responding here when that’s done. I cannot locate any txt records on the domain you provided. If the verification is successful we can remove the domain from the other account so you can use it on yours.
Hey @SamO I have added the txt files
Based on ticket ID in your DNS record, this seems to be resolved. Do you still need help?
HI I am also having the exact same issue my domain is huntersforaccess.org
Hi @mckinleyatlas :wave:t6: welcome to the forums! I see you wrote in about in our helpdesk. We have followed up on your response to ticket #159746. Thanks so much!
Hi I’m having the same problem for domain: devanshag.com, I used this domain for one of my website and later deleted it, now I cannot re-add this domain. Please help!
@DevanshCodes Please verify domain ownership and let us know by responding here when that’s done.
Hi, I’ve added that in the records, can you please verify. Thanks!
Hi, I have removed the dns zones. The domain should be useable at this point?
No SamO, I’m still unable to add the domain in Netlify. Can you please check soon.
This should be resolved.
Hello! I am facing the same issue.
Domain: psychedelic(dot)monster
It is register via Porkbun
I added txt record. please verify my ownership
