Preview Links append "index" to URL
Hello all,
I have the Show_preview_links option enabled for my collection. The “view preview” or “view live” links add “index” to the end of the url. For instance:
The link should be - www.myblog.com/blog/post
but it renders as - www.myblog.com/blog/post-index
Is there a way to change this? It also affects unpublished posts in the editorial workflow.
It seems like another user has the same issue:
Incorrect preview link for nested structure back in February of '21.
We’re both using a nested structure, (blog/post-title/index.md)
I suspect this may be causing the issue?
How does Netlify-CMS handle preview links when the collection is nested?
I found the solution:
preview_path: '{{dirname}}'
Was the correct line, which I found via this thread.
Hope it helps other HUGO users in the future!
EDIT: I also had to add the specific directory manually, so in my case:
preview_path: 'blog/{{dirname}}'
I suppose the work-around here is to change each instance per collection to reflect which directory to correctly point to.
Thanks for reporting back. It’ll definitely be of use to other users!
