Home
Support Forums
Page not found issue for part of site
Have this page I have been working on. Everything works locally and most things also work in netlify except from two buttons that should redirect to homepage. Instead I get an error that page is not found. The URL is correct and if I push enter in the URL it works. Frustrating issue that this was not an issue yesterday? Anyone that can help? In link below when you push confirm is where the issue is.
HI @George
Welcome to the Netlify community
You have the action in your submit button and for some reason form="" also.
<input type="submit" value="Confirm" form="" action="home_page.html" class="btn">
action goes in the <form> tag. <input type="submit"> on MDN
Thanks for the reply.
I have used:
<input type="submit" value="Confirm" formaction="home_page.html" class="btn">
So how should I write this?
Hi @George,
You don’t seem to have any account with your forum email address and you removed the link you had in your post.
Is it safe to assume the problem is solved?
You might have something like this
<form method="POST" action="/signup">
  <input type="text" name="username" />
  <input type="email" name="user_email" />
  <input type="submit" value="Signup" />
</form>
I have created https://heuristic-edison-90f40a.netlify.app/ for my essay writing. But it redirecting to page not found page.
Hi @gladysrobinson889,
All you have are .docx and .pdf files. Do note that using Netlify as a remote storage solution is not allowed as per the Terms of Service and we’d be asking you to take this website down as soon as possible.
Hi,
Thanks. Managed to find a workaround. So things seems to work.
