Home
Support Forums
Page not found (Could you please help?) Thank you in advance!
This is my link.
https://ushio-firstwebsite.netlify.app](https://ushio-firstwebsite.netlify.app/
Thank you.
Below is Visual studio code screenshot of html,css,jpg file that I uploaded.
Hi @ushio
How did you deploy your site? Did you use the drag-n-drag via the Netlify UI?
[Support Guide] I’ve deployed my site but I still see "Page not found” might help you figure out what has/hasn’t happened here.
Happy to help you you are still having issues.
Yes, I used drag and drop.
Where you able to solve the issue after reading the support guide I linked to?
I read it but can’ t find any.
there are the file inside the folder I drag in to.
That looks fine.
On your original deploy log, do you see message like this
Did you try downloading your site from the deploy log (using the icon highlighted below)?
Hi, @ushio. These are the filenames of the files uploaded:
/style3.css
/index.html.html
/cat.jpg
All sorts of programs “hide” information. Chrome now hides the protocol and www subdomain from URLs. IDEs and OSes will hide file extensions - which is what happened here.
To summarize, do you not have an index.html file. You have an index.html.html file. Because this isn’t the expected filename, that content is available here:
https://ushio-firstwebsite.netlify.app/index.html
If you correct that filename, you will be able to use the original URL above (https://ushio-firstwebsite.netlify.app/). If there are other questions or concerns, please let us know.
It somehow worked after I drag and drop the folder again.
Not sure why…
Thank you for your help!!
Not sure why…
