I have a lambda function that works locally if I copy the dependencies to the functions folder. I would like to know how to compile or zip the dependencies into the function.
I used this repo for reference:
https://github.com/DavidWells/netlify-functions-express
from the (old) blog article:
How to run Express.js apps with Netlify Functions
My function looks simple enough:
const serverless = require('serverless-http');
const { app } = require('./server/main');
exports.handler = serverless(app())
./server/main is an angular universal compiled express app that refers to a small set of angular source html/js/css files to server side render them. These files are not included in the compiled lambda function. I have tried using netlify-lambda and other things to no avail.
Another possible solution is to read the published static files from the file system, but I don’t know where those are.
@attilacsanyi asks this question in:
Angular SSR with Clover Engine and Express on Netlify
but he never returns to say if he got it working and/or how.
