Not showing index.html after build vuepress
No problems however the main link does not point to the index.html that is there
@discord-buttons Welcome to the Netlify community. You will need to provide more information before anyone can help you.
In the meantime, have you downloaded your deploy to ensure that the index.html file is at the top level of your file structure?
Hi @discord-buttons,
You probably have configured the wrong publish path. I tried your repo and discovered this:
You’re publishing the dist directory which only has the 404 page. However there’s an index.html inside the documentation folder and that might be the one you’re looking for. If that is, your publish path needs to be docs/.vuepress/dist/documentation.
ah i see it isn’t actually generating the proper index.html for me which is quite odd
nevermind! i know what i have done wrong. i’ve misplaced the index.md
