Home
Support Forums
Not showing anything please help
https://app.netlify.com/sites/gaurav2021/deploys/60e1a11ba3ec230100dc5b09
Hi @gauravsgc
Your deploy log reads
9:54:06 PM: The project was built assuming it is hosted at /WebPage/.
9:54:06 PM: You can control this with the homepage field in your package.json.
and your package.json reads
"homepage": "https://gauravsgc.github.io/WebPage",
So what should I write there
If you want your site served from / then you can simply remove it from your package.json.
Thanks I was also on same track as a learner i will try it
thanks done…https://60e1ce5fab3d9400090b4781--gaurav2021.netlify.app/
It looks like you got it working, @gauravsgc. Was it @coelmay’s solution that helped?
Definitely it helped me thanks so much
