Home
Support Forums
Node-sass probleme
the app is working before add node-sass package but after adding the node-sass I get this problem
look to the all message error in this link
Hi @aymanouch
What version of node-sass are you using in your project?
If you are using a version < v6.0, can you either upgrade to the latest, or try this solution.
If you are still having issues, can you share your git repository.
Are you actually using Netlify CMS?
