fool
June 26, 2020, 10:31pm
43
Hiya @rob @rajhanskumarseo and @elchaparrito1 ! Sorry to hear about the trouble.
Please link us to deploys where you are having trouble so we can take a look.
@elchaparrito1 your problem is different than the topic of this thread:
9:32:23 AM: npm ERR! path /opt/build/repo/package.json
…which makes me think you cannot build locally either - npm doesn’t work without a package.json and this error says there is no package.json. Looking at your repo, I think you need to set a “base” directory of “pfn”, since this is where your package.json
is.
Hey @fool , look at below added logs.
12:30:15 AM: Build ready to start
12:30:17 AM: build-image version: 3031d4c9e432fd7016f6279fc9ad706f9205d845
12:30:17 AM: build-image tag: v3.3.17
12:30:17 AM: buildbot version: 1f35b3abd6e2bf5230d8edf68072840fdec1513f
12:30:17 AM: Fetching cached dependencies
12:30:18 AM: Starting to download cache of 250.9MB
12:30:30 AM: Finished downloading cache in 12.222311333s
12:30:30 AM: Starting to extract cache
12:30:41 AM: Finished extracting cache in 11.501110472s
12:30:41 AM: Finished fetching cache in 23.780886183s
12:30:41 AM: Starting to prepare the repo for build
12:30:42 AM: Preparing Git Reference refs/heads/master
12:30:44 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘build’ versus ‘build/’ in the Netlify UI
12:30:44 AM: Starting build script
12:30:44 AM: Installing dependencies
12:30:44 AM: Python version set to 2.7
12:30:44 AM: Started restoring cached node version
12:30:50 AM: Finished restoring cached node version
12:30:51 AM: v10.21.0 is already installed.
12:30:51 AM: Now using node v10.21.0 (npm v6.14.4)
12:30:51 AM: Started restoring cached build plugins
12:30:51 AM: Finished restoring cached build plugins
12:30:52 AM: Attempting ruby version 2.6.2, read from environment
12:30:53 AM: Using ruby version 2.6.2
12:30:53 AM: Using PHP version 5.6
12:30:53 AM: 5.2 is already installed.
12:30:53 AM: Using Swift version 5.2
12:30:53 AM: Started restoring cached node modules
12:30:53 AM: Finished restoring cached node modules
12:30:53 AM: Installing NPM modules using NPM version 6.14.4
12:31:00 AM: npm WARN deprecated popper.js@1.16.1: You can find the new Popper v2 at @popperjs /core, this package is dedicated to the legacy v1
12:31:01 AM: npm WARN deprecated core-js@1.2.7: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
12:31:26 AM: npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
12:31:27 AM: npm WARN deprecated urix@0.1.0: Please see GitHub - lydell/urix: [DEPRECATED] Makes Windows-style paths more unix and URI friendly.
12:31:27 AM: npm WARN deprecated resolve-url@0.2.1: GitHub - lydell/resolve-url: [DEPRECATED] Like Node.js’ `path.resolve`/`url.resolve` for the browser.
12:31:37 AM: npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
12:31:37 AM: npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
12:31:49 AM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
12:31:59 AM: npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
12:32:24 AM: npm WARN rm not removing /opt/build/repo/node_modules/.bin/jest as it wasn’t installed by /opt/build/repo/node_modules/jestnpm WARN rm not removing /opt/build/repo/node_modules/.bin/rimraf as it wasn’t installed by /opt/build/repo/node_modules/rimrafnpm WARN rm not removing /opt/build/repo/node_modules/.bin/semver as it wasn’t installed by /opt/build/repo/node_modules/semvernpm WARN rm not removing /opt/build/repo/node_modules/.bin/json5 as it wasn’t installed by /opt/build/repo/node_modules/json5
12:32:24 AM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/babel-runtime/node_modules/core-js
12:32:24 AM: > node -e “try{require(‘./postinstall’)}catch(e){}”
12:32:24 AM: > core-js@3.6.5 postinstall /opt/build/repo/node_modules/react-app-polyfill/node_modules/core-js
12:32:26 AM: npm notice created a lockfile as package-lock.json. You should commit this file.
12:32:26 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.0.7 (node_modules/react-scripts/node_modules/fsevents):
12:32:26 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.0.7: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
12:32:26 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/jest-haste-map/node_modules/fsevents):
12:32:26 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
12:32:26 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/fsevents):
12:32:26 AM: npm WARN notsup Unsupported engine for watchpack-chokidar2@2.0.0: wanted: {“node”:“<8.10.0”} (current: {“node”:“10.21.0”,“npm”:“6.14.4”})
12:32:26 AM: npm WARN notsup Not compatible with your version of node/npm: watchpack-chokidar2@2.0.0
12:32:26 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/watchpack/node_modules/chokidar/node_modules/fsevents):
12:32:26 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
12:32:26 AM: npm WARN bootstrap@4.4.1 requires a peer of jquery@1.9.1 - 3 but none is installed. You must install peer dependencies yourself.
12:32:26 AM: npm WARN react-radio-button-group@1.2.8 requires a peer of react@^15.4.1 but none is installed. You must install peer dependencies yourself.
12:32:26 AM: npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
12:32:26 AM: added 281 packages from 177 contributors, removed 260 packages, updated 1338 packages and audited 1623 packages in 91.526s
12:32:27 AM: 47 packages are looking for funding
12:32:27 AM: run npm fund
for details
12:32:27 AM: found 3 vulnerabilities (1 low, 2 moderate)
12:32:27 AM: run npm audit fix
to fix them, or npm audit
for details
12:32:27 AM: NPM modules installed
12:32:28 AM: Started restoring cached go cache
12:32:28 AM: Finished restoring cached go cache
12:32:28 AM: Installing Go version 1.12
12:32:33 AM: unset GOOS;
12:32:33 AM: unset GOARCH;
12:32:33 AM: export GOROOT=‘/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64’;
12:32:33 AM: export PATH=“/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64/bin:${PATH}”;
12:32:33 AM: go version >&2;
12:32:33 AM: export GIMME_ENV=“/opt/buildhome/.gimme_cache/env/go1.12.linux.amd64.env”
12:32:33 AM: go version go1.12 linux/amd64
12:32:33 AM: Installing missing commands
12:32:33 AM: Verify run directory
12:32:34 AM:
12:32:34 AM: ┌─────────────────────────────┐
12:32:34 AM: │ Netlify Build │
12:32:34 AM: └─────────────────────────────┘
12:32:34 AM:
12:32:34 AM: ❯ Version
12:32:34 AM: @netlify /build 2.0.10
12:32:34 AM:
12:32:34 AM: ❯ Flags
12:32:34 AM: deployId: 5ef645bff14c750007b37094
12:32:34 AM: mode: buildbot
12:32:34 AM:
12:32:34 AM: ❯ Current directory
12:32:34 AM: /opt/build/repo
12:32:34 AM:
12:32:34 AM: ❯ Config file
12:32:34 AM: No config file was defined: using default values.
12:32:34 AM:
12:32:34 AM: ❯ Context
12:32:34 AM: production
12:32:34 AM:
12:32:34 AM: ┌────────────────────────────────┐
12:32:34 AM: │ 1. Build command from settings │
12:32:34 AM: └────────────────────────────────┘
12:32:34 AM:
12:32:34 AM: $ CI= yarn build
12:32:34 AM: bash: yarn: command not found
12:32:34 AM:
12:32:34 AM: │ “build.command” failed │
12:32:34 AM:
12:32:34 AM: Error message
12:32:34 AM: Command failed with exit code 127: CI= yarn build
12:32:34 AM:
12:32:34 AM: Error location
12:32:34 AM: In Build command from settings:
12:32:34 AM: CI= yarn build
12:32:34 AM:
12:32:34 AM: Resolved config
12:32:34 AM: build:
12:32:34 AM: command: CI= yarn build
12:32:34 AM: publish: /opt/build/repo/build
12:32:34 AM: Caching artifacts
12:32:34 AM: Started saving node modules
12:32:34 AM: Finished saving node modules
12:32:34 AM: Started saving build plugins
12:32:34 AM: Finished saving build plugins
12:32:34 AM: Started saving pip cache
12:32:41 AM: Finished saving pip cache
12:32:41 AM: Started saving emacs cask dependencies
12:32:41 AM: Finished saving emacs cask dependencies
12:32:41 AM: Started saving maven dependencies
12:32:41 AM: Finished saving maven dependencies
12:32:41 AM: Started saving boot dependencies
12:32:41 AM: Finished saving boot dependencies
12:32:41 AM: Started saving go dependencies
12:32:43 AM: Finished saving go dependencies
12:32:43 AM: Error running command: Build script returned non-zero exit code: 1
12:32:43 AM: Failing build: Failed to build site
12:32:43 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
12:32:43 AM: Finished processing build request in 2m25.996062862s
Thanks @fool . I got so far into the weeds of the issue, I didn’t look closely at the error pertaining to the file structure.
fool
June 29, 2020, 6:02pm
46
Here’s the problem:
We do not install yarn for you unless:
there is a yarn.lock
file in the root of the repo (xor in your base
directory, if set!)
you have a yarn dependency in package.json
which is in the root of your repo (xor your base
directory, if set).
Adding CI= npm run build
does not work for me. Also tried with the empty env variable. Anyone using vue-cli with the same issue? Thanks!
8:03:12 PM: > vue-cli-service build 8:03:13 PM: - Building for production... 8:03:17 PM: ERROR Failed to compile with 1 errors6:03:17 PM 8:03:17 PM: error in ./src/main.js 8:03:17 PM: Module build failed (from ./node_modules/thread-loader/dist/cjs.js): 8:03:17 PM: Thread Loader (Worker 0) 8:03:17 PM: [BABEL] /opt/build/repo/src/main.js: Cannot find module '@babel/compat-data/corejs3-shipped-proposals'
luke
July 1, 2020, 1:57am
48
Hi, @dbarcosb , I see that error in the site builds but it doesn’t appear to be related to CI=true
in any way.
The error appears similar to this:
opened 07:41PM - 14 Apr 20 UTC
closed 08:07PM - 14 Apr 20 UTC
Thank you for reporting an issue.
This issue tracker is for bugs and is… sues found within Node.js core.
If you require more general support please file an issue on our help
repo. https://github.com/nodejs/help
Please fill in as much of the template below as you're able.
Version: output of `node -v`
Platform: output of `uname -a` (UNIX), or version and 32 or 64-bit (Windows)
Subsystem: if known, please specify affected core module name
* **Version**: Node.js 13.13
* **Platform**: 19.4.0 Darwin Kernel Version 19.4.0
* **Subsystem**: ES modules
### What steps will reproduce the bug?
Enter details about your bug, preferably a simple code snippet that can be
run using `node` directly without installing third-party dependencies.
npm install @babel/compat-data
node -e "require('@babel/compat-data/corejs3-shipped-proposals')"
### What is the expected behavior?
It should load the module as expected in Node.js 13.12
If possible please provide textual output instead of screenshots.
### What do you see instead?
Error: Cannot find module '@babel/compat-data/corejs3-shipped-proposals'
Require stack:
- /tmp/[eval]
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:952:15)
at Function.resolve (internal/modules/cjs/helpers.js:78:19)
at [eval]:1:9
at Script.runInThisContext (vm.js:131:20)
at Object.runInThisContext (vm.js:297:38)
at Object.<anonymous> ([eval]-wrapper:10:26)
at Module._compile (internal/modules/cjs/loader.js:1123:30)
at evalScript (internal/process/execution.js:94:25)
at internal/main/eval_string.js:23:3 {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/tmp/[eval]' ]
### Additional information
Caught by the Babel CI: https://travis-ci.com/github/babel/babel/jobs/319348116#L360
Tell us anything else you think we should know.
The regression was likely introduced in https://github.com/nodejs/node/pull/32351.
The file structure of `@babel/compat-data` can be simplified w.l.o.g as
package.json
corejs3-shipped-proposals.js
data/corejs3-shipped-proposals.json
and the `package.json`:
```json
"exports": {
"./corejs3-shipped-proposals": "./data/corejs3-shipped-proposals.json"
The `corejs3-shipped-proposals.js` is a proxy which delegates to "./data/corejs3-shipped-proposals.json" for Node.js < 13.3 support.
```js
module.exports = require("./data/corejs3-shipped-proposals.json");
I would recommend testing that solution, quoting:
For those babel users who are affected by this issue after upgrading to node.js 13.13/12.17, please upgrade @babel/preset-env
to 7.9.0.
Please let us know if it works (or not) and/or if there are other questions.
Hi @luke , thanks for your answer! I am editing my first reply because this actually worked, the problem was there. Investigated with other threads and finally it worked, thanks!
I’m still getting an error even after editing my build command settings
3:04:08 PM: Build ready to start
3:04:09 PM: build-image version: ca811f47d4c1cbd1812d1eb6ecb0c977e86d1a1d
3:04:09 PM: build-image tag: v3.3.20
3:04:09 PM: buildbot version: 78b5536ab4f742c26705d3e953381b9cde6e22ef
3:04:10 PM: Fetching cached dependencies
3:04:10 PM: Failed to fetch cache, continuing with build
3:04:10 PM: Starting to prepare the repo for build
3:04:10 PM: No cached dependencies found. Cloning fresh repo
3:04:10 PM: git clone GitHub - tattooseoul/ouitresjolie_1
3:04:11 PM: Preparing Git Reference refs/heads/master
3:04:12 PM: Starting build script
3:04:12 PM: Installing dependencies
3:04:12 PM: Python version set to 2.7
3:04:13 PM: v12.18.0 is already installed.
3:04:14 PM: Now using node v12.18.0 (npm v6.14.4)
3:04:14 PM: Started restoring cached build plugins
3:04:14 PM: Finished restoring cached build plugins
3:04:14 PM: Attempting ruby version 2.7.1, read from environment
3:04:16 PM: Using ruby version 2.7.1
3:04:16 PM: Using PHP version 5.6
3:04:16 PM: 5.2 is already installed.
3:04:16 PM: Using Swift version 5.2
3:04:16 PM: Started restoring cached node modules
3:04:16 PM: Finished restoring cached node modules
3:04:16 PM: Started restoring cached yarn cache
3:04:16 PM: Finished restoring cached yarn cache
3:04:16 PM: Installing yarn at version 1.22.4
3:04:16 PM: Installing Yarn!
3:04:16 PM: > Downloading tarball…
3:04:16 PM: [1/2]: https://yarnpkg.com/downloads/1.22.4/yarn-v1.22.4.tar.gz → /tmp/yarn.tar.gz.JaBDhdIiX0
3:04:16 PM: % Total % Received % Xferd Average Speed Time Time Time Current
3:04:16 PM: Dload Upload Total Spent Left Speed
3:04:16 PM: 0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
3:04:16 PM: 100 80 100 80 0 0 287 0 --:–:-- --:–:-- --:–:-- 287
3:04:17 PM: 0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
3:04:17 PM: 100 93 100 93 0 0 155 0 --:–:-- --:–:-- --:–:-- 577
3:04:17 PM: 100 630 100 630 0 0 710 0 --:–:-- --:–:-- --:–:-- 710
3:04:17 PM: 100 1215k 100 1215k 0 0 928k 0 0:00:01 0:00:01 --:–:-- 928k
3:04:17 PM: [2/2]: https://yarnpkg.com/downloads/1.22.4/yarn-v1.22.4.tar.gz.asc → /tmp/yarn.tar.gz.JaBDhdIiX0.asc
3:04:17 PM: 100 84 100 84 0 0 3108 0 --:–:-- --:–:-- --:–:-- 3108
3:04:17 PM: 100 97 100 97 0 0 1786 0 --:–:-- --:–:-- --:–:-- 1786
3:04:17 PM: 100 634 100 634 0 0 7313 0 --:–:-- --:–:-- --:–:-- 7313
3:04:17 PM: 0 1028 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
3:04:17 PM: 100 1028 100 1028 0 0 8042 0 --:–:-- --:–:-- --:–:-- 1003k
3:04:18 PM: > Verifying integrity…
3:04:18 PM: gpg: Signature made Mon 09 Mar 2020 03:52:13 PM UTC using RSA key ID
3:04:18 PM: gpg: Good signature from “Yarn Packaging yarn@dan.cx ”
3:04:18 PM: gpg: WARNING: This key is not certified with a trusted signature!
3:04:18 PM: gpg: There is no indication that the signature belongs to the owner.
3:04:18 PM: Primary key fingerprint:
3:04:18 PM:
3:04:18 PM: > GPG signature looks good
3:04:18 PM: > Extracting to ~/.yarn…
3:04:18 PM: > Adding to $PATH…
3:04:18 PM: > Successfully installed Yarn 1.22.4! Please open another terminal where the yarn
command will now be available.
3:04:18 PM: Installing NPM modules using Yarn version 1.22.4
3:04:19 PM: yarn install v1.22.4
3:04:19 PM: warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
3:04:19 PM: [1/4] Resolving packages…
3:04:20 PM: warning @gridsome /vue-remark > @gridsome /source-filesystem > chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
3:04:20 PM: warning @gridsome /vue-remark > @gridsome /transformer-remark > unified > @types /vfile > @types /vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
3:04:24 PM: [2/4] Fetching packages…
3:04:24 PM: warning Pattern [“vscode-textmate@GitHub - octref/vscode-textmate: A library that helps tokenize text using Text Mate grammars. ”] is trying to unpack in the same destination “/opt/build/.yarn_cache/v6/npm-vscode-textmate-4.0.1-e65aabe2227febda7beaad31dd0fca1228c5ddf3/node_modules/vscode-textmate” as pattern [“vscode-textmate@git+https://github.com/octref/vscode-textmate.git”]. This could result in non-deterministic behavior, skipping.
3:04:30 PM: warning mini-css-extract-plugin@0.5.0: Invalid bin field for “mini-css-extract-plugin”.
3:04:30 PM: warning url-loader@1.1.2: Invalid bin field for “url-loader”.
3:04:40 PM: info fsevents@1.2.13: The platform “linux” is incompatible with this module.
3:04:40 PM: info “fsevents@1.2.13” is an optional dependency and failed compatibility check. Excluding it from installation.
3:04:40 PM: info fsevents@2.1.3: The platform “linux” is incompatible with this module.
3:04:40 PM: info “fsevents@2.1.3” is an optional dependency and failed compatibility check. Excluding it from installation.
3:04:40 PM: [3/4] Linking dependencies…
3:04:40 PM: warning “gridsome-plugin-remark-shiki > shiki > onigasm > tslint@5.20.1” has unmet peer dependency “typescript@>=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >=3.0.0-dev || >= 3.1.0-dev || >= 3.2.0-dev”.
3:04:40 PM: warning “gridsome-plugin-remark-shiki > shiki > onigasm > tslint > tsutils@2.29.0” has unmet peer dependency “typescript@>=2.1.0 || >=2.1.0-dev || >=2.2.0-dev || >=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >= 3.0.0-dev || >= 3.1.0-dev”.
3:04:40 PM: warning “gridsome-plugin-remark-shiki > shiki-languages > vscode-textmate@4.0.1” has unmet peer dependency “oniguruma@^7.0.0”.
3:04:40 PM: warning “gridsome-plugin-remark-shiki > shiki-languages > vscode-textmate@4.0.1” has unmet peer dependency “onigasm@^2.1.0”.
3:04:40 PM: warning “gridsome-plugin-remark-shiki > shiki > shiki-themes > vscode-textmate@4.0.1” has unmet peer dependency “oniguruma@^7.0.0”.
3:04:40 PM: warning " > vue-fuse@2.2.1" has unmet peer dependency “vue@^2.6.10”.
3:04:47 PM: [4/4] Building fresh packages…
3:04:50 PM: success Saved lockfile.
3:04:50 PM: Done in 31.27s.
3:04:50 PM: NPM modules installed using Yarn
3:04:51 PM: Started restoring cached go cache
3:04:51 PM: Finished restoring cached go cache
3:04:51 PM: go version go1.14.4 linux/amd64
3:04:51 PM: Installing missing commands
3:04:51 PM: Verify run directory
3:04:52 PM:
3:04:52 PM: ┌─────────────────────────────┐
3:04:52 PM: │ Netlify Build │
3:04:52 PM: └─────────────────────────────┘
3:04:52 PM:
3:04:52 PM: ❯ Version
3:04:52 PM: @netlify /build 2.0.27
3:04:52 PM:
3:04:52 PM: ❯ Flags
3:04:52 PM: deployId: 5f1050476066b00009a7a632
3:04:52 PM: mode: buildbot
3:04:52 PM:
3:04:52 PM: ❯ Current directory
3:04:52 PM: /opt/build/repo
3:04:52 PM:
3:04:52 PM: ❯ Config file
3:04:52 PM: /opt/build/repo/netlify.toml
3:04:52 PM:
3:04:52 PM: ❯ Context
3:04:52 PM: production
3:04:52 PM:
3:04:52 PM: ┌────────────────────────────────────┐
3:04:52 PM: │ 1. build.command from netlify.toml │
3:04:52 PM: └────────────────────────────────────┘
3:04:52 PM:
3:04:52 PM: $ CI= npm run build
3:04:52 PM: > base@ build /opt/build/repo
3:04:52 PM: > gridsome build
3:04:53 PM: Gridsome v0.7.19
3:04:53 PM: Initializing plugins…
3:04:54 PM: Load sources - 0.02s
3:04:54 PM: Create GraphQL schema - 0.06s
3:04:54 PM: Create pages and templates - 0.02s
3:04:54 PM: Generate temporary code - 0.03s
3:04:54 PM: Bootstrap finish - 1.37s
3:04:54 PM: Compiling assets…
3:05:08 PM: Compile assets - 14.13s
3:05:08 PM: Execute GraphQL (3 queries) - 0s
3:05:08 PM: Render HTML (3 files) - 0.29s
3:05:08 PM: Process files (0 files) - 0s
3:05:09 PM: Processing images (9 images) - 0%Processing images (9 images) - 100%Process images (9 images) - 0.96s
3:05:09 PM: Error: Sitemap plugin is missing a required siteUrl config.
3:05:09 PM: at /opt/build/repo/node_modules/@gridsome /plugin-sitemap/index.js:15:13
3:05:09 PM: at Plugins.run (/opt/build/repo/node_modules/gridsome/lib/app/Plugins.js:141:17)
3:05:09 PM: at async module.exports (/opt/build/repo/node_modules/gridsome/lib/build.js:42:3)
3:05:10 PM: npm ERR! code ELIFECYCLE
3:05:10 PM: npm ERR! errno 1
3:05:10 PM: npm ERR! base@ build: gridsome build
3:05:10 PM: npm ERR! Exit status 1
3:05:10 PM: npm ERR! Failed at the base@ build script.
3:05:10 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
3:05:10 PM: npm ERR! A complete log of this run can be found in:
3:05:10 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-07-16T13_05_10_513Z-debug.log
3:05:10 PM:
3:05:10 PM: ┌─────────────────────────────┐
3:05:10 PM: │ “build.command” failed │
3:05:10 PM: └─────────────────────────────┘
3:05:10 PM:
3:05:10 PM: Error message
3:05:10 PM: Command failed with exit code 1: CI= npm run build
3:05:10 PM:
3:05:10 PM: Error location
3:05:10 PM: In build.command from netlify.toml:
3:05:10 PM: CI= npm run build
3:05:10 PM:
3:05:10 PM: Resolved config
3:05:10 PM: build:
3:05:10 PM: command: CI= npm run build
3:05:10 PM: commandOrigin: config
3:05:10 PM: publish: /opt/build/repo/dist
3:05:10 PM: Caching artifacts
3:05:10 PM: Started saving node modules
3:05:10 PM: Finished saving node modules
3:05:10 PM: Started saving build plugins
3:05:10 PM: Finished saving build plugins
3:05:10 PM: Started saving yarn cache
3:05:10 PM: Finished saving yarn cache
3:05:10 PM: Started saving pip cache
3:05:10 PM: Finished saving pip cache
3:05:10 PM: Started saving emacs cask dependencies
3:05:10 PM: Finished saving emacs cask dependencies
3:05:10 PM: Started saving maven dependencies
3:05:10 PM: Finished saving maven dependencies
3:05:10 PM: Started saving boot dependencies
3:05:10 PM: Finished saving boot dependencies
3:05:10 PM: Started saving go dependencies
3:05:10 PM: Finished saving go dependencies
3:05:13 PM: Error running command: Build script returned non-zero exit code: 1
3:05:13 PM: Failing build: Failed to build site
3:05:13 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
3:05:13 PM: Finished processing build request in 1m3.582997458s
I also tried to edit my package.json file with “CI= npm run build” but still not working…
fool
July 16, 2020, 3:55pm
52
Can you build locally? This quote from your logs makes me think you cannot, or that you do not have netlify configured identically to your local build environment. This failure is not related to our build system, but to your code:
Problem solved! Fixing the sitemap error did the trick.
For the record, I didn’t have to set the build command to “CI= npm run build”. A standard “gridsome build” command worked.
Thank you.
Hi Netlify Team,
Why is that only “CI = npm run build” works fine for me and not “CI = yarn build” even when my default build script is “yarn build”? Pardon my ignorance, I expected “CI = yarn build” to also work fine since “yarn build” is the equivalence of “npm run build”.
Hi @techiesodiq ,
Just to confirm, you’re using CI= yarn build
? Note the lack of space between CI
and =
Thanks for the correction about the omission. I never knew that space matters. Mind you, what I used was “CI = npm run build” with the space and it worked. Meanwhile, are you saying that “CI= yarn build” too will work?
That’s strange. From what I remember CI = npm run build
never worked, the space was always a problem. I can’t find a thread at the moment where I had corrected someone using space, but yeah, even the docs don’t use space:
Hi guys, can someone help me?
My build commands is, CI=false yarn build
I keep getting the same error, already try it change to CI= npm run build, npm build, yarn build…
Hey there, @fdevos1
Can you share your full deploy log as well as a link to your site please? Thanks!
Sure
https://suspicious-bohr-3acb41.netlify.app
10:59:17 AM: Build ready to start
10:59:18 AM: build-image version: c6001ed68662a13e5deb24abec2b46058c58248a
10:59:18 AM: build-image tag: v3.9.0
10:59:18 AM: buildbot version: 29fef7ab5dc568ca81434ff0643fc14ddc7b88ab
10:59:19 AM: Fetching cached dependencies
10:59:19 AM: Starting to download cache of 807.0MB
10:59:23 AM: Finished downloading cache in 3.935226948s
10:59:23 AM: Starting to extract cache
10:59:51 AM: Finished extracting cache in 28.558113439s
10:59:51 AM: Finished fetching cache in 32.657957407s
10:59:51 AM: Starting to prepare the repo for build
10:59:52 AM: Preparing Git Reference refs/heads/master
10:59:54 AM: Parsing package.json dependencies
10:59:54 AM: Starting build script
10:59:54 AM: Installing dependencies
10:59:54 AM: Python version set to 2.7
10:59:55 AM: Started restoring cached node version
10:59:58 AM: Finished restoring cached node version
10:59:58 AM: v12.18.0 is already installed.
10:59:59 AM: Now using node v12.18.0 (npm v6.14.4)
10:59:59 AM: Started restoring cached build plugins
10:59:59 AM: Finished restoring cached build plugins
10:59:59 AM: Attempting ruby version 2.7.2, read from environment
11:00:00 AM: Using ruby version 2.7.2
11:00:01 AM: Using PHP version 5.6
11:00:01 AM: Started restoring cached yarn cache
11:00:19 AM: Finished restoring cached yarn cache
11:00:20 AM: No yarn workspaces detected
11:00:20 AM: Started restoring cached node modules
11:00:20 AM: Finished restoring cached node modules
11:00:20 AM: Installing NPM modules using Yarn version 1.22.10
11:00:21 AM: yarn install v1.22.10
11:00:21 AM: [1/4] Resolving packages…
11:00:22 AM: [2/4] Fetching packages…
11:00:24 AM: info @netlify /routing-local-proxy-darwin-arm64@0.30.2: The platform “linux” is incompatible with this module.
11:00:24 AM: info “@netlify /routing-local-proxy-darwin-arm64@0.30.2” is an optional dependency and failed compatibility check. Excluding it from installation.
11:00:24 AM: info @netlify /routing-local-proxy-darwin-arm64@0.30.2: The CPU architecture “x64” is incompatible with this module.
11:00:24 AM: info @netlify /routing-local-proxy-darwin-x64@0.30.2: The platform “linux” is incompatible with this module.
11:00:24 AM: info “@netlify /routing-local-proxy-darwin-x64@0.30.2” is an optional dependency and failed compatibility check. Excluding it from installation.
11:00:24 AM: info @netlify /routing-local-proxy-win32-x64@0.30.2: The platform “linux” is incompatible with this module.
11:00:24 AM: info “@netlify /routing-local-proxy-win32-x64@0.30.2” is an optional dependency and failed compatibility check. Excluding it from installation.
11:00:24 AM: info fsevents@2.3.2: The platform “linux” is incompatible with this module.
11:00:24 AM: info “fsevents@2.3.2” is an optional dependency and failed compatibility check. Excluding it from installation.
11:00:24 AM: info fsevents@1.2.13: The platform “linux” is incompatible with this module.
11:00:24 AM: info “fsevents@1.2.13” is an optional dependency and failed compatibility check. Excluding it from installation.
11:00:24 AM: [3/4] Linking dependencies…
11:00:24 AM: warning " > react-lottie@1.2.3" has incorrect peer dependency “react@^0.14.7 || ^15.0.0 || ^16.0.0”.
11:00:24 AM: warning “react-outside-click-handler > airbnb-prop-types@2.16.0” has incorrect peer dependency “react@^0.14 || ^15.0.0 || ^16.0.0-alpha”.
11:00:24 AM: warning " > styled-components@5.3.1" has unmet peer dependency “react-is@>= 16.8.0”.
11:00:24 AM: warning " > @testing-library /user-event@12.8.3" has unmet peer dependency “@testing-library /dom@>=7.21.4”.
11:00:32 AM: [4/4] Building fresh packages…
11:00:32 AM: success Saved lockfile.
11:00:32 AM: Done in 10.93s.
11:00:32 AM: NPM modules installed using Yarn
11:00:32 AM: Started restoring cached go cache
11:00:32 AM: Finished restoring cached go cache
11:00:32 AM: go version go1.14.4 linux/amd64
11:00:32 AM: Installing missing commands
11:00:32 AM: Verify run directory
11:00:34 AM:
11:00:34 AM: ────────────────────────────────────────────────────────────────
11:00:34 AM: Netlify Build
11:00:34 AM:
11:00:34 AM: ❯ Version
11:00:34 AM: @netlify /build 18.13.7
11:00:34 AM:
11:00:34 AM: ❯ Flags
11:00:34 AM: baseRelDir: true
11:00:34 AM: buildId: 615b08b45d87521ca8d0675c
11:00:34 AM: deployId: 615b08b45d87521ca8d0675e
11:00:34 AM:
11:00:34 AM: ❯ Current directory
11:00:34 AM: /opt/build/repo
11:00:34 AM:
11:00:34 AM: ❯ Config file
11:00:34 AM: /opt/build/repo/netlify.toml
11:00:34 AM:
11:00:34 AM: ❯ Context
11:00:34 AM: production
11:00:34 AM:
11:00:34 AM: 1. Build command from Netlify app
11:00:34 AM:
11:00:34 AM: $ CI=false yarn build
11:00:34 AM: yarn run v1.22.11
11:00:34 AM: $ react-scripts build
11:00:36 AM: Creating an optimized production build…
11:01:33 AM: Failed to compile.
11:01:33 AM:
11:01:33 AM: /opt/build/repo/src/components/DocEdit/index.tsx
11:01:33 AM: TypeScript error in /opt/build/repo/src/components/DocEdit/index.tsx(204,23):
11:01:33 AM: Argument of type ‘string’ is not assignable to parameter of type ‘never’. TS2345
11:01:33 AM: 202 | value={createNotification}
11:01:33 AM: 203 | maxLength={55}
11:01:33 AM: > 204 | {…register(“notification_text”)}
11:01:33 AM: | ^
11:01:33 AM: 205 | />
11:01:33 AM: 206 |
11:01:33 AM: 207 |
11:01:33 AM: error Command failed with exit code 1.
11:01:33 AM: info Visit yarn run | Yarn for documentation about this command.
11:01:33 AM:
11:01:33 AM: ────────────────────────────────────────────────────────────────
11:01:33 AM: “build.command” failed
11:01:33 AM:
11:01:33 AM: Error message
11:01:33 AM: Command failed with exit code 1: CI=false yarn build
11:01:33 AM:
11:01:33 AM: Error location
11:01:33 AM: In Build command from Netlify app:
11:01:33 AM: CI=false yarn build
11:01:33 AM:
11:01:33 AM: Resolved config
11:01:33 AM: build:
11:01:33 AM: command: CI=false yarn build
11:01:33 AM: commandOrigin: ui
11:01:33 AM: publish: /opt/build/repo/build
11:01:33 AM: publishOrigin: ui
11:01:33 AM: redirects:
11:01:33 AM: - from: ‘*’
11:01:33 AM: status: 200
11:01:33 AM: to: /index.html
11:01:33 AM: redirectsOrigin: config
11:01:33 AM: Caching artifacts
11:01:33 AM: Started saving node modules
11:01:33 AM: Finished saving node modules
11:01:33 AM: Started saving build plugins
11:01:33 AM: Finished saving build plugins
11:01:33 AM: Started saving yarn cache
11:01:50 AM: Finished saving yarn cache
11:01:50 AM: Started saving pip cache
11:01:50 AM: Finished saving pip cache
11:01:50 AM: Started saving emacs cask dependencies
11:01:50 AM: Finished saving emacs cask dependencies
11:01:50 AM: Started saving maven dependencies
11:01:50 AM: Finished saving maven dependencies
11:01:50 AM: Started saving boot dependencies
11:01:50 AM: Finished saving boot dependencies
11:01:50 AM: Started saving rust rustup cache
11:01:50 AM: Finished saving rust rustup cache
11:01:50 AM: Started saving go dependencies
11:01:50 AM: Finished saving go dependencies
11:01:50 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
11:01:50 AM: Creating deploy upload records
11:01:50 AM: Failing build: Failed to build site
11:01:50 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2
11:01:50 AM: Finished processing build request in 2m31.781179656s
perry
October 4, 2021, 9:48pm
67
fdevos1:
11:01:33 AM:
11:01:33 AM: | ^
11:01:33 AM: 206 |
11:01:33 AM: 207 |
hi there, this is an unrelated issue. You have some errors in your code, so we never get to complete the build step. Does this work locally?
leabaty
February 24, 2022, 10:43am
68
Thanks a lot for this ! Got my problem solved so quickly !
