Hey,
I don’t observe the same behavior on my local. I’m using the following command:
[build]
base = "./"
command = "pushd web3/ && npm run build && npm run export && popd && pushd functions/ && go build -o api ./cmd && popd"
publish = "web3/out/"
[build.environment]
GO_VERSION = "1.17"
GO_IMPORT_PATH = "github.com/Dentrax/myapp/functions"
[functions]
directory = "functions/"
On my local:
$ netlify build
builds successfully. But if I commit to my repo, here is how netlify tries to build:
11:02:34 AM: $ pushd web3/ && npm run build && npm run export && popd && pushd functions/ && go build -o api ./cmd && popd
11:02:34 AM: ~/.gimme_cache/gopath/src/github.com/Dentrax/myapp/functions/web3 ~/.gimme_cache/gopath/src/github.com/Dentrax/myapp/functions
11:02:34 AM: > myapp@0.1.0 build
11:02:34 AM: > next build
11:02:34 AM: sh: 1: next: not found
Please notice that, myapp/functions/web3
is wrong. i expect myapp/web3
instead. So I ended up Netlify build fails because it first try to build my function first. Instead, it should build the web3 dir instead by issuing next build command.
My config on build settings:
Base directory
Not set
Build command
Not set
Publish directory
Not set
Root dir:
├── .git/
├── .netlify/
├── functions/
├── netlify.toml
└── web3/
Any thoughts?
