Hi,
TL:DR;
Netlify build crashes trying to fetch a ghost plugin.
(netlify-plugin-inline-critical-css was removed from package.json and netlify.toml but every build keeps trying to fetch it).
I experience crashes with netlify-plugin-inline-critical-css plugin since a few days ( Error: Failed to inline critical CSS. Penthouse timed out after …)
The plugin is invoked from netlify.toml
# [[plugins]]
# package = "netlify-plugin-inline-critical-css"
# [plugins.inputs]
# directoryFilter = ["!annees", "!specialites", "!tags"]
and cited as devDependency in package.json.
Therefore I want to remove the plugin for now to have a fresh build. I remove it from netlify.toml and uninstall it from npm devdependencies.
However, Netlify build keeps trying to invoke the plugin even though I erased every trace of it.
I tried to change the Ubuntu version (16 <> 20) to have a fresh environment but same crash trying to import the ghost plugin.
**Plugin "netlify-plugin-inline-critical-css" internal error**
Could not import plugin:
- Site is: recommandations-medicales.netlify.app
- Build log:
Could not import plugin: Error: The module '/opt/build/repo/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 83. This version of Node.js requires NODE_MODULE_VERSION 93. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install` ).
While loading "netlify-plugin-inline-critical-css" from Netlify app at Object.Module._extensions..node (node:internal/modules/cjs/loader:1189:18) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/build/repo/node_modules/canvas/lib/bindings.js:3:18) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12)
Error properties: { code: 'ERR_DLOPEN_FAILED' }
Thanks a lot,
JB
