Home
Support Forums
Netlify is stuck after build is generated and not able to publish the site
I am facing problem when deploying site via Netlify, according to log there is no error in build and it is generated successfully but further execution is stuck at that point since more than hour. and I also tried same steps many times.
Please help me out I have also attached snapshots,
Thanks.
Hi @dericklee,
It looks like a problem with your build pipeline more than Netlify. Netlify waits for an exit code to determine the status of a build. As long as your build command doesn’t return a status code (which seems to be happening here), Netlify will continue waiting.
