Netlify dev working locally but erroring out when deploying to netlify edge
I’ve a simple netlify edge function which is working locally using netlify dev but when I am deploying it to the netlify it’s erroring out saying worker
Dec 17, 04:32:54 PM: error  ReferenceError: Worker is not defined
    at https://esm.sh/v135/@duckdb/duckdb-wasm@1.28.0/denonext/duckdb-wasm.mjs:2:656
    at https://esm.sh/v135/@duckdb/duckdb-wasm@1.28.0/denonext/duckdb-wasm.mjs:2:323
    at https://esm.sh/v135/@duckdb/duckdb-wasm@1.28.0/denonext/duckdb-wasm.mjs:2:29046
import { getJsDelivrBundles, selectBundle, ConsoleLogger, AsyncDuckDB } from "https://esm.sh/@duckdb/duckdb-wasm@1.28.0";
import { Int } from "https://esm.sh/v135/apache-arrow@13.0.0/type.js";
const JSDELIVR_BUNDLES = getJsDelivrBundles();
const bundle = await selectBundle(JSDELIVR_BUNDLES);
const worker_url = new URL(bundle.mainWorker!, import.meta.url).href;
const worker = new Worker(worker_url, { type: 'module' })
const logger = new ConsoleLogger();
const db = new AsyncDuckDB(logger, worker);
await db.instantiate(bundle.mainModule, bundle.pthreadWorker);
URL.revokeObjectURL(worker_url);
const res = await fetch('https://github.com/cwida/duckdb-data/releases/download/v1.0/taxi_2019_04.parquet');
await db.registerFileBuffer('taxi_2019_04.parquet', new Uint8Array(await res.arrayBuffer()));
BigInt.prototype.toJSON = function () { return this.toString() }
export default async function handler(req: Request, context: Context) {
    const conn = await db.connect();
    const arrowResult = await conn.query<{total_count: Int}>(`SELECT COUNT(*) AS total_count
                                            FROM 'taxi_2019_04.parquet'
                                            WHERE pickup_at BETWEEN '2019-04-15' AND '2019-04-20'`)
                                      //arrowResult.get(0)?.total_count
    const result = arrowResult.toArray().map((row) => row.toJSON());
    return Response.json(result[0]);
export const config: Config = {
    path: "/duckdb",
Can you bundle this together as a repo that we can use to test and debug?
Sure… here is the sample repo
Interestingly, I tried to deploy your repo and it seems to work without any changes: main–stellular-biscuit-75918c.netlify.app/duckdb
How are you getting the error?
