Netlify: command not found
this worked for me, thanks :grinning:
This worked for me, too.
Thanks so much for coming back and letting us know! We are glad you found a solution!
I’m facing same error after install any npm global package this msg came from Windows because command or any terminal tool is running in the background.
Yarn is in the same directory where netlify installed and it work fine but not netlify so i guess that it’s related to entries because it didn’t read the new entries.
Restart system or logout and login into system is the solution i come with.
Can you clarify what your issue is? Can you install the cli globally?
same issue Netlify command is not found.
‘netlify’ is not recognized as an internal or external command,
operable program or batch file.
from git bash:
bash: netlify: command not found.
Workaround :slightly_smiling_face:
