I would like to use Netlify CMS to manage the content of my blog. First of all - thank you for that, it is a wonderful tool.
When developing the blog on localhost
, I added the CMS under /admin
without any problems - it just worked. I was about to modify test posts and the changes were reflected on my Github repository.
I finished the development and I am deploying the static site to my own server, under my domain. I do this by compiling the site and copying the result to a local directory through Github Actions (I do not think it matters for the question, but just in case).
I see my blog on https://example.com
and when attempt to load https://example.com/admin
, I first get the “netlify cms” page with a “Login to GitHub” button.
When pressing this button, I Immediately get a popup page from https://api.netlify.com/auth?provider=github&site_id=example.com&scope=repo
with the message
No Auth Provider Found
Make sure you've configured the API credentials for Github from the **Access** part of your Netlify site dashboard.
(How is Netlify even in the authentication loop when my site is deployed on my own server?)
I found a very similar question Netlify CMS Github login doesn't work without localhost and the answer points to GitHub | Netlify CMS | Open-Source Content Management System, and step # 1 is “Follow the authentication provider setup steps in the Netlify docs”.
In these docs, the Github part was easy. I then have Use OAuth provider tokens on your site | Netlify Docs
And this is the place I am lost
Specifically: what is “your Netlify site”?
Should I register my site deployed on my server with Netlify? I do not remember doing that when developing the web site and I do not see any sites on my Netlify account.
Any help would be greatly appreciated
