Home
Support Forums
Netlify CMS does not deploy to Git Submodule
I have a Netlify CMS setup on the site hosted on Netlify.
I am using git submodules inside the parent git repository. I linked the Netlify CMS with the folder of git-submodule using back-end git-gateway.
The issue is when I make and change/publish on Netlify CMS, it deploys to the parent git repository but not to the git-submodule repository.
Can you please guide me on how can I ensure that NetlifyCMS deploys to git-submodule?
Hi @RolandSibelink,
Would you share your config? By default CMS will only write to the repo connected to the Git Gateway and writing directly into submodules might not be possible. But if you can detail your use case, we might have a better answer.
