I was trying to get new Git Gateway token and rebuild my app but it did not resolve the issue. when I’m removing the token I can see 404 error on the network tab. and after adding the token again I’m getting a 401
Edit: this is just the stock blog project created from the template. I did not modify anything on it
Sorry to hear you encountered some login errors with the Netlify CMS. It looks like you posted roughly one week ago-- thanks so much for your patience. Can you confirm if you still encountering obstacles?
Then, after that is complete, please request a password reset for your login to that Identity instance. This is done under the Identity tab of the site’s settings at Netlify.
If that doesn’t resolve the issue, please let us know.
