Need help regarding SSL/TLS certificate mismatch
Hey Guys,
Our client has a project in Netlify and the primary domain is www.finishesfactory.au and while A records and CNAME records required are already added in Web Central and can confirm the Netlify DNS status is active in green already, we are having issues accessing finishesfactory.au and www.finishes factory.au - it is showing SSL cert security issue. I’ve check the current SSL/TLS certificate and it only covers finishesfactory.com.au which is an Alias so I attempted to renew certificate hoping it will provide a new cert but now getting this ACME TXT error thing. Not sure what to do now but Netlify support can definitely help I guess?
Hey @FELIXVILL13 :wave:,
Thanks for reaching out!
We’ve gone ahead and created a support ticket for you, so our team can follow up with you directly via email from the help desk. Our Support crew will be in touch with you by email soon.
Great news: these days anyone can reach out to Netlify Support. First, you can try getting an answer using Ask Netlify, our helpful AI search tool. If your question isn’t answered there, you can submit a ticket using the support form, and we’ll take it from there.
We’re keeping the community around for swapping ideas, sharing tips and tricks, and talking shop with other folks building on the platform — but for support issues, tickets are the way to go.
Thanks for being here, and keep an eye out for that email from us!
