My custom domain return ERR_CONNECTION_REFUSED with Netlify DNS
I created a custom domain: leyabogados.es and in the panel show as is working with Netlify DNS. I could add this morning a SSL Certificate so the DNS should be fine.
But the problem is that when I open my domain in the browser have the following error:
“ERR_CONNECTION_REFUSED.”
Thanks in advance.
Regards.
I don’t speak Spanish, however it appears to load correctly for me.
Have you tried a different browser, a different device?
Looks like I cant access from my IP :confused:
I tried with my mobile without WiFi network and is working, if I activate WiFi have the same error “ERR_CONNECTION_REFUSED”
Thanks.
Then it would appear the issue is with your network/computer and not Netlify.
