Hello,
I’m trying to enable manual initialization so I can better organize my config files.
This is what I currently have in admin/index.html:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1.0" />
<title>Content Manager</title>
<!-- Include the script that enables Netlify Identity on this page. -->
<script src="https://identity.netlify.com/v1/netlify-identity-widget.js"></script>
</head>
<body>
<!-- Include the script that builds the page and powers Netlify CMS -->
<script src="../cms/index.js" type="module"></script>
</body>
</html>
And this is what I have in cms/index.js:
// This global flag enables manual initialization.
window.CMS_MANUAL_INIT = true
// Usage with import from npm package
import CMS, { init } from '../../node_modules/netlify-cms-app'
import pages from './pages'
* Optionally pass in a complete config object and set a flag
* (`load_config_file: false`) to ignore the `config.yml`.
* For example, the code below contains a complete config. The
* `config.yml` will be ignored when setting `load_config_file` to false.
* It is not required if the `config.yml` file is missing to set
* `load_config_file`, but will improve performance and avoid a load error.
init({
config: {
backend: {
branch: 'master',
load_config_file: false,
media_folder: 'static/images/uploads',
public_folder: '/images/uploads',
publish_mode: 'editorial_workflow',
collections: [
pages
// The registry works as expected, and can be used before or after init.
// CMS.registerPreviewTemplate(...);
I get this error when I try to open the cms:
Failed to load module script: Expected a JavaScript module script but the server responded with a MIME type of "text/html". Strict MIME type checking is enforced for module scripts per HTML spec.
How do I resolve this issue?
I added type="module"
to resolve another issue. Do I need to add some sort of webpack config or something?
