Hi there, I’m building a Gatsby theme that uses Netlify CMS with manual initialisation. I’ve created a Gatsby site that consumes this theme and deployed with Netlify.
I then started using the Netlify Identity and everything works out.
I’m getting this odd behavious in which when first landing on the admin page the login iframe is rendered but the visibility is the to false so I end up with the modal overlay alone. This can be thankfully dismissed and I can then click on the [Login with Netlify Identity] button and trigger the modal again which get displayed as expected.
I’ll be investinging further in the next coming days, I just thought to ask if anyone has had any similar behaviour or can suggest what I should look out for.
hmm, before we start digging, can you confirm that you are seeing these issues in a browser that doesn’t have any extensions that might interfere? an incognito window is an easy way to check.
Hi @LuigiClaudio. Are you by any chance using gatsby-plugin-netlify-cms? It has the Netlify Identity widget already included, so if you manually add the script to your admin index, you might run into some trouble. Not sure if it’s the case, but if you have included the identity widget manually, I’d advise you to remove it.
hi, thanks for the reply. Yes I’m using the gatsby-plugin-netlify-cms, I forgot to mention. I’m not including the script to my admin index file, I’m using the enableIdentityWidget flag in the plugin options in gatsby-config and enabling Identity in Netlify admin. I would share my repo but it has some deps to private packages, I could create a similar project and remove those deps if needed…
Thanks for the mention @jen, this looks like a very similar issue. I’ll try to create a reproduction. @LuigiClaudio any chance you can share your repo/an example repo with this issue?
