Lovable - Failed to load module scrip
HI I have a lovable.dev app where I have an error: Failed to load module script: Expected a JavaScript module script but the server responded with a MIME type of “application/octet-stream”. Strict MIME type checking is enforced for module scripts per HTML spec.
My site was built using lovable.dev. It runs locally fine, but getting a white screen here.
My site link is https://tracker.chadyoma.com/
This is my first time using lovable as well as netlify, so any help would be appreciated
@icealec Your build is deploying your ‘source code’ not the ‘build output’:
Tell lovable this and see if it can adjust the files or guide you further.
