Who is effected by this bug:
Blockchain developers who want to use serverless functions
when using netlify-cli’s netlify dev to test locally,
the bufferutil module causes serverless functions not to reload when the file is updated.
(Hangs on ◈ Reloading function {name}…).
this module is used heavily used in the websocket module, which in turn is used web3 libraries such as ethers.js which is how i discovered the problem.
bufferutil is a library used in the websocket library written in c for speed. Using only the fallback pure javascript version works. Something about the C compiled version breaks reloading.
What you are meaning by reload@vinh-perfectstorm? Netlify functions have an execution time limit of 10 seconds, and won’t (at least from my understanding and experience) reload themselves.
yes, completely forgot to mention this is in service of the serverless function reloading on save when using netlify’s local dev environment “netlify dev” command
Looks like the utf-8-validate module inside of the ‘ws’ (websocket) module also causes this problem since it appears to be using compiled libraries written in C. Updating the code to use the fallback bypasses the error
looks like these two dependencies within the ws websocket library are unique in that they’re written in C++ for speed but for whatever reason I dont understand, importing them twice prevents the local development pipeline from reloading serverless functions.
Thanks for reaching out. My apologies, can you please let me know if you are currently encountering the bug you have described in your first post? If so, can you please share a site and reproduction so that we can see it?
I can’t reproduce this. I made a change to the said file:
✔ Waiting for framework port 5173. This can be configured using the 'targetPort' property in the netlify.toml
│ ◈ Server now ready on http://localhost:8888 │
◈ Reloading function api...
◈ Reloaded function api
Thanks for reaching out! If you have a moment, please do share the solution the local devs shared with you. This would definitely help future forums members who encounter something similar.
Sure. I didn’t mean local devs as in people working with me - I’m working solo on a personal project . I meant that you need to make changes to your local dev environment, as suggested in the OP.
To be extra precise, I locally commented out parts of the code in node_modules/bufferutil/index.js and node_modules/utf-8-validate/index.js
For example:
'use strict';
// COMMENTED OUT TO FIX NETLIFY FUNCTIONS NOT RELOADING: https://answers.netlify.com/t/local-serverless-function-does-not-reload-because-of-bufferutil/73131/9
// try {
// module.exports = require('node-gyp-build')(__dirname);
// } catch (e) {
module.exports = require('./fallback');
My experience of this issue was that functions would reload the first few times but eventually stop working. I am pretty sure I left it for a very long time once and they did eventually reload, but that’s clearly a non-starter when iterating.
external_node_modules for netlify.toml is supposed to fix this, but for some reason, it wouldn’t work, however, when I tried including the node_module paths, that fixed it.
# netlify.toml
[functions]
included_files = [
# For some reason this works to fix "bufferutil" error on
# Netlify Function and external_node_modules does not
"node_modules/bufferutil/**",
"node_modules/utf-8-validate/**"
