Greetings!
I have a domain (zivkarmi.com) registered with Dreamhost, and wanted to connect it to my site recently published to Netlify. My Netlify site is at zivkarmi.netlify.app.
In Dreamhost, I created a CNAME record for www
with value set to zivkarmi.netlify.app.
This worked for pointing www.zivkarmi.com
to the Netlify site. However, it didn’t work for just zivkarmi.com
After some reading and discussion with Dreamhost support, I came across a Netlify help article that said I should create an A record. So in addition to the CNAME record, I also have an A record for my domain on Dreamhost pointing to 104.198.14.52
While I was working on the solution with Dreamhost support, I also at some point selected Netlify DNS for my domains. I now have the following settings under Settings > Domain Management > Custom Domains:
Now, for the issue: Going to www.zivkarmi.com
correctly loads the website, over HTTPS. However, entering the URL without the www.
results in a “Your connection is not private” error. I would prefer that this URL redirect directly to the https://www.
version of the website, but instead it simply redirects to https://zivkarmi.com, and displays the error.
I should also mention I have a _redirects
file in my site root, but I am not sure if it is setup correctly, or if it is even working. When I download the deployed version of the website, there is no _redirects file present. The contents of that file are as follows:
# Source --> Target
http://zivkarmi.com/* https://www.zivkarmi.com:splat 301!
https://zivkarmi.com/* https://www.zivkarmi.com/:splat 301!
# Redirect for SPAs
# Source: https://docs.netlify.com/routing/redirects/rewrites-proxies/#history-pushstate-and-single-page-apps
/* /index.html 200
Thank you in advance for any help. I am happy to provide further information if needed.
