Hi, Iโve been having an intermittent build failure across branch deploys and deploy previews for a few days, ever since I upgraded packages - most notably, upgrading Gatsby to v5. The PR for that upgrade is galasa-dev/galasa.dev#557. The sites (galasa
and galasa-local
) get the following build failure on gatsby build --log-pages
3:10:50 PM: error There was a problem loading the local build command. Gatsby may not be installed. Perhaps you need to run "npm install"? No native build was found for platform=linux arch=x64 runtime=node abi=108 uv=1 libc=glibc node=18.13.0
3:10:50 PM: loaded from: /opt/build/repo/node_modules/lmdb and package: @lmdb/lmdb-linux-x64
3:10:50 PM:
3:10:50 PM:
3:10:50 PM: Error: No native build was found for platform=linux arch=x64 runtime=node abi= 108 uv=1 libc=glibc node=18.13.0
3:10:50 PM: loaded from: /opt/build/repo/node_modules/lmdb and package: @lmdb/lmdb-lin ux-x64
3:10:50 PM:
3:10:50 PM: - index.js:64 Function.load.path
3:10:50 PM: [repo]/[node-gyp-build-optional-packages]/index.js:64:9
3:10:50 PM:
3:10:50 PM: - index.js:20 Object.load [as default]
3:10:50 PM: [repo]/[node-gyp-build-optional-packages]/index.js:20:30
3:10:50 PM:
3:10:50 PM: - native.js:9 Object.<anonymous>
3:10:50 PM: [repo]/[lmdb]/native.js:9:34
3:10:50 PM:
3:10:50 PM: - loader:1218 Module._compile
3:10:50 PM: node:internal/modules/cjs/loader:1218:14
3:10:50 PM:
3:10:50 PM: - loader:1272 Object.Module._extensions..js
3:10:50 PM: node:internal/modules/cjs/loader:1272:10
3:10:50 PM:
3:10:50 PM: - loader:1081 Module.load
3:10:50 PM: node:internal/modules/cjs/loader:1081:32
3:10:50 PM:
3:10:50 PM: - loader:922 Function.Module._load
3:10:50 PM: node:internal/modules/cjs/loader:922:12
3:10:50 PM:
3:10:50 PM: - loader:1105 Module.require
3:10:50 PM: node:internal/modules/cjs/loader:1105:19
3:10:50 PM:
3:10:50 PM: - helpers:103 require
3:10:50 PM: node:internal/modules/cjs/helpers:103:18
3:10:50 PM:
3:10:50 PM: - cache-lmdb.ts:1 Object.<anonymous>
3:10:50 PM: [repo]/[gatsby]/src/utils/cache-lmdb.ts:1:1
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM:
3:10:50 PM: โ
3:10:50 PM: "build.command" failed
3:10:50 PM: โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ
3:10:50 PM: โ
3:10:50 PM: Error message
3:10:50 PM: Command failed with exit code 1: gatsby build --log-pages (https://ntl.fyi/exit-code-1)
3:10:50 PM: โ
3:10:50 PM: Error location
3:10:50 PM: In Build command from Netlify app:
3:10:50 PM: gatsby build --log-pages
3:10:50 PM: โ
3:10:50 PM: Resolved config
3:10:50 PM: build:
3:10:50 PM: command: gatsby build --log-pages
3:10:50 PM: commandOrigin: ui
3:10:50 PM: environment:
3:10:50 PM: - GATSBY_GALASA_ENV
3:10:50 PM: - NPM_FLAGS
3:10:50 PM: - REVIEW_ID
3:10:50 PM: publish: /opt/build/repo/public
3:10:50 PM: publishOrigin: ui
Iโve been using the latest Essential Gatsby plugin. Iโve now removed the plugin, to see if that helps things, but it still fails intermittently.
Any ideas? Thanks for your help!
