Hi, I’m on the Pro plan and need the function timeout increased to 26 seconds for two sites:
fabulous-hotteok-42fc08.netlify.app
teal-zabaione-270a76.netlify.app
*I’m proxying Anthropic AI API calls to process clinical documents and they need more than 10 seconds. I have timeout = 26 set in my netlify.toml but it doesn’t seem to be taking effect.
I have timeout = 26 set in my netlify.toml under [functions."summarise"] and the @netlify/plugin-functions-install-core plugin is running successfully on each deploy. However functions are still timing out at what appears to be 10 seconds — I get a 504 Gateway Timeout error when processing large documents via the Anthropic API. The deploy summary shows 3 functions deployed and 1 plugin ran successfully each time.
