so I just created a website with Weebly and exported it then did a manual deploy to Netlify but when I previewed the site everything was normal but the title and navigations at the top of the page where not showing up at all I can click on them like if I hover there is a place to go but the text isn’t showing its completely normal in Weebly though.
Does Weebly support HTML export?
I don’t see how this is a Netlify issue - Netlify is serving what you must have uploaded. If the export from Weebly is incorrect, it’s going to display incorrect.
ah okay ill try to ask support there and see what happens thank you.
