You will need to copy and paste the contents of the deploy log (or at least the error messages) in order for anyone to help you. No one else can access the link you shared because it’s unique and private to your account.
SOLUTION: I solved the problem. The problems are only the image file names. For example I had 20 images that is called “20-car.jpg”. And I changed them like car01.jpg. And the problem is over.
