Home
Support Forums
I encountered a problem when adding my github.io domain as cutom domain in netlify
I have a website hosted on netlify: https://eyasugc.netlify.app/. However, I also would like to add my github pages domain name, i.e., eyaget.github.io, as a custom domain name. When I tried to add this custom domain, I received the following message: " github.io is already registered. If you registered this domain name through a different registrar, select Add domain to begin delegating it to Netlify". When I click the “Add domain” button, I received the following message: “Another site is already using this domain. Domains must be unique across Netlify. Currently another site is using this domain. If you don’t know which site, please contact support for guidance”. Another site is not using my github domian, i.e., eyaget.github.io. I am not sure why netlify is indicating that it is being used by another site. Please help to check the matter.
Thank you,
Eyasu.
hi there @eyaget, you won’t be able to set up eyaget.github.io as a custom domain for your netlify site.
Github owns any subdomains under github.io and they are reserved for use with projects that are published using github pages only.
you would need to purchase a completely custom domain, something like eyaget.com and then set that up to work with your netlify site if you wanted to use a custom domain.
Hi Perry,
I see. Thank you very much for your clarification!
Best Regards,
Eyasu.
