I am facing issues in socket io client side after deploying
do help with this
error
Hiya, sorry you are having trouble with your build.
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem :slight_smile: Additionally, this Support Guide houses all of our resources for debugging build and deploy issues.
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide more information such as what you have already tried, what your build settings are, your package.json, a link to your live site etc. Thanks!
@Hemnath Are you trying to host the socket server on Netlify?
If so, then that’ll be your problem, as you won’t be able to host a long running express server on Netlify.
I have hosted my Express server in my Backend(Heroku) and Frontend react in Netllify does this works fine?
Error Fixed it is in my backend side Thankyou guys…
Thanks for coming back and letting us know! Happy building
Yes, as you’ve already found that’ll work fine.
