How to rename an entry with Netlify CMS
I am using Hugo with Netlify CMS on Bitbucket.
Netlify CMS will automatically generate entries with title of article, but is it any way I can rename an entry after creation?
Thanks for your help.
I’m afraid that doesn’t sound like something that’s possible from within the CMS itself. However, you can always rename the file in the repo and push the change.
Also, there’s a configuration option that determines how file names are created: Configuration Options | Netlify CMS | Open-Source Content Management System
