How to Fix Brother Printer Offline Problems on Windows and Mac
A Brother printer offline issue can interrupt printing even when the printer appears to be powered on and connected correctly. Your computer may display an “Offline,” “Printer Offline,” or “Unable to Print” status, and documents can remain stuck in the print queue. This problem can occur on Windows or Mac computers and may be related to network connectivity, printer settings, outdated drivers, or temporary communication errors.
For Support: Click Here
Fortunately, most Brother printer offline problems can be resolved with basic troubleshooting. This guide explains the common causes and practical steps to bring your Brother printer back online.
Why Is My Brother Printer Offline?
A Brother printer may show offline when the computer cannot communicate with it properly. Common reasons include:
  • Weak or disconnected Wi-Fi connection
  • Printer and computer connected to different networks
  • Brother printer not selected as the default printer
  • “Use Printer Offline” option enabled
  • Stuck or corrupted print jobs
  • Outdated or damaged printer drivers
  • Incorrect printer port configuration
  • Temporary router or network problems
  • Printer entering sleep or deep sleep mode
  • Changes to the printer’s network address
Identifying the cause can make troubleshooting much easier.
Check the Brother Printer Connection
Start by checking whether your printer is powered on and ready. Look at the printer display for warning messages related to paper jams, low supplies, open covers, or network problems.
For a wireless printer, confirm that it is connected to Wi-Fi. Your computer and Brother printer should normally be connected to the same local network.
If you are using a USB connection, disconnect the USB cable and reconnect it securely. You can also try another USB port to determine whether the original connection is causing the problem.
Restart the Printer, Computer, and Router
A simple restart can clear temporary communication errors.
Turn off your Brother printer and computer. If the printer uses Wi-Fi, restart your wireless router as well. Wait briefly before turning the devices back on.
Allow the printer to reconnect completely before trying another print job. This process can resolve temporary network conflicts and connectivity problems.
Disable Use Printer Offline on Windows
Windows includes a setting that can intentionally place a printer in offline mode.
Open Settings and navigate to Bluetooth & devices > Printers & scanners. Select your Brother printer and open the print queue.
Check the printer settings and make sure Use Printer Offline is not enabled. If it is selected, disable it and check whether the printer status changes to online or ready.
The exact menu wording may vary depending on your Windows version.
Set Brother Printer as the Default Printer
Your computer may be sending documents to another printer or an older copy of the same Brother printer.
Open Printers & scanners, locate your active Brother printer, and make sure you are selecting the correct device when printing.
If appropriate for your Windows configuration, set the Brother printer as your preferred or default printer. Remove obsolete duplicate printer entries if they are causing confusion.
Clear the Print Queue
A failed print job can sometimes prevent additional documents from printing.
Open your Brother printer’s print queue and cancel unnecessary or stuck documents. Once the queue is empty, restart the printer and try printing a simple test document.
If documents cannot be removed normally, restarting the Windows Print Spooler service may help clear the queue.
Check the Wi-Fi Connection
If your Brother printer keeps going offline, the wireless connection should be checked carefully.
Make sure the printer has a stable Wi-Fi signal and has not disconnected from the router. If you recently changed your Wi-Fi name, password, router, or internet equipment, the printer may need to be connected to the wireless network again.
Also verify that the computer is connected to the same network as the printer.
If possible, move the printer closer to the router temporarily to determine whether weak signal strength is contributing to the issue.
Remove and Re-Add the Brother Printer
Removing and reinstalling the printer can refresh its connection with your computer.
On Windows, go to Settings > Bluetooth & devices > Printers & scanners, select the affected printer, and remove it. Then use Add device to detect and reinstall the printer.
On a Mac, open System Settings > Printers & Scanners. Remove the problematic printer and add it again.
After adding the printer, send a test page to check the connection.
Update or Reinstall the Printer Driver
An outdated, corrupted, or incompatible printer driver can cause a Brother printer to appear offline.
Check your printer’s exact model and operating system before installing driver or software updates. For security, obtain printer software from Brother’s official support resources rather than unknown third-party download websites.
If the existing installation appears damaged, uninstalling the printer software and performing a clean reinstall may restore communication.
Check the Printer Port and IP Address
Network printers may receive a different IP address after the router restarts. If Windows continues trying to communicate with the printer through an outdated address or incorrect port, the printer may remain offline.
Advanced users can check the printer’s network configuration and compare its current IP address with the configured Windows printer port.
If they do not match, updating or reinstalling the printer connection can resolve the problem.
Brother Printer Offline on Mac
If your Brother printer is offline on Mac, first confirm that both devices are connected to the same network.
Open System Settings > Printers & Scanners and select your Brother printer. Check for paused or failed print jobs and clear them when necessary.
If the printer remains unavailable, remove it and add it again. Restarting the Mac, printer, and router can also restore network communication.
How to Prevent Brother Printer Offline Problems
Keeping your printer software and operating system updated can reduce compatibility problems. Maintain a stable network connection and avoid placing the printer where the Wi-Fi signal is extremely weak.
If the offline problem frequently returns after router restarts, reviewing the printer’s network configuration may help identify changing IP addresses or other local network issues.
Frequently Asked Questions
Why does my Brother printer say offline even though it is connected?
The computer may be using an incorrect printer entry, old network address, paused queue, offline setting, or damaged driver. Verify the connection and printer configuration.
How do I get my Brother printer back online?
Confirm that the printer is powered on and connected, disable any offline setting, clear stuck print jobs, restart your devices, and reinstall the printer if necessary.
Why does my Brother printer keep going offline?
Repeated offline problems can be caused by unstable Wi-Fi, network changes, driver problems, incorrect port settings, or the printer receiving a different network address.
Can restarting the router fix a Brother printer offline issue?
It can help when the problem is caused by temporary network communication issues. After restarting the router, wait for both the computer and printer to reconnect before testing the printer.
Should I reinstall my Brother printer?
If basic connection checks do not resolve the issue, removing and re-adding the printer or reinstalling its driver can refresh the configuration and fix communication problems.
Conclusion
A Brother printer offline message usually means communication between the printer and computer has been interrupted rather than indicating a serious hardware failure. Start by checking the power and network connection, then clear the print queue, verify printer settings, and restart your devices. If the problem continues, re-add the printer, update its driver, and check its network or port configuration. Following these troubleshooting steps can help restore the Brother printer to an online state and prevent recurring printing interruptions.
