frontend-admin-next.netlify.app
I need help with subdomain TXT record verification. This is regarding the subdomain verification feature, not domain transfer between teams.
@kjxbyz Help in what way?
If it’s something that requires manual intervention by the Netilfy team you’re always better off using the Support Form here (https://www.netlify.com/support/), even if you’re on a Free/Starter Plan, and even if they initially reject you.
They check the forum less frequently, and then you end up waiting additional time for them spot your post and then put it into the ticket queue.
@kjxbyz I’ve never seen that before, but I guess it means you’re just stuck waiting extra time.
I have submitted the form.
