Is there a way to update the repository in build settings ?
I’m using Azure DevOps and using CLI to setup the repository build settings by netlify init --manual
hey @berikat,
you can find the complete CLI reference here:
https://cli.netlify.com/
looks like this command might be what you need:
https://cli.netlify.com/commands/link
