Help unlike GitHub repository from Netlify project
Please:
  • choose at least one appropriate tag for your post (more is better)
  • a short description & what you have tried to fix it (DNS really may take up to 48 hours to propagate.)
    I need help unlinking a GitHub repo from a Netlify project because I created a new project that uses the same repo. I don’t want to delete the old project because it contains form data I want to retain.
  • build log errors, screenshots, etc
  • your Netlify instance name, for example: deluding-chances-2b123.netlify.com
    https://covid19hg.netlify.com/
Did you use the search before posting?
Yes and they all require action from support staff.
What about reading through our https://answers.netlify.com/search?q=common%20issue?
Done! Thanks for your work on covid19.
And just so you know, you can download a CSV of your form data by clicking here: https://app.netlify.com/sites/covid19hg/forms/, then clicking into the specific form you want, and then hitting the “Download CSV” button.
