Home
Support Forums
Help to debu deploy
Failing build: Failed to parse configuration
6:22:16 AM: Failed during stage ‘Reading and parsing configuration files’:
When resolving config file /opt/build/repo/netlify.toml:
Base directory does not exist: /opt/build/repo/path-to-react-app
: exit status 1
Hi @harshitadaswani,
You’ve an invalid netlify.toml file. I’d advise you to remove it as it’s not required at the moment.
