Home
Support Forums
Help! Problem with deploying my nextjs app
PLEASE help me!
I get this error:
8:07:03 AM: npm ERR! code EJSONPARSE
8:07:03 AM: npm ERR! path /opt/build/repo/package.json
8:07:03 AM: npm ERR! JSON.parse Unexpected token “}” (0x7D) in JSON at position 165 while parsing near “…nt”: “next lint”,\n },\n “dependencies”:…"
8:07:03 AM: npm ERR! JSON.parse Failed to parse JSON data.
8:07:05 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
8:07:03 AM: npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
8:07:03 AM: npm ERR! A complete log of this run can be found in:
8:07:03 AM: npm ERR! /opt/buildhome/.npm/_logs/2021-11-03T04_37_03_836Z-debug.log
8:07:03 AM: Error during NPM install
8:07:03 AM: Build was terminated: Build script returned non-zero exit code: 1
8:07:05 AM: Failing build: Failed to build site
I need your help that how resolve this problem.
Hi @mmsafari
Line 8 of the package.json in your repository contains a comma at the end meaning it is invalid.
"lint": "next lint",
Removing the comma will solve this issue. Assuming there are no other issues, your build should succeed.
hi , thanks for your attention, I deleted what you said, but the problem and error still remain
8:44:16 AM: Installing NPM modules using NPM version 8.1.0
8:44:17 AM: npm ERR! code EJSONPARSE
8:44:17 AM: npm ERR! path /opt/build/repo/package.json
8:44:17 AM: npm ERR! JSON.parse Unexpected token “}” (0x7D) in JSON at position 140 while parsing near “…t”: “next start”,\n },\n “dependencies”:…"
8:44:17 AM: npm ERR! JSON.parse Failed to parse JSON data.
8:44:17 AM: npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
8:44:17 AM: npm ERR! A complete log of this run can be found in:
8:44:17 AM: npm ERR! /opt/buildhome/.npm/_logs/2021-11-03T05_14_17_109Z-debug.log
8:44:17 AM: Error during NPM install
8:44:17 AM: Build was terminated: Build script returned non-zero exit code: 1
8:44:17 AM: Creating deploy upload records
8:44:17 AM: Failing build: Failed to build site
8:44:17 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
8:44:17 AM: Finished processing build request in 12.467417674s
Capture2
Is there anything I need to change?
Captured
I didn’t mean to remove the entire line, simply the comma (,) at the end of the line.
You now have the same issue with the start script line which ends in a comma
"start": "next start",
It needs to look like this
Thanks a lot,
My problem is solved
