Help Needed: Netlify Forms Not Working with YAML-Based Site
Hi everyone,
I’m having trouble getting forms to work on my Netlify site, which is built using YAML. Its name is https://mockumentary.xyz/.
I started from a preset website and tried to include a form using the following YAML snippet directly in my markdown files:
yaml
media:
  type: FormBlock
  data-netlify: true
However, it doesn’t seem to be working. I’m not sure if I’m adding it correctly or if there’s something I’m missing in the setup.
I also tried to include some html right after the ending of the YAML coding, but none of this created any reactions from Neftlify form detection.
On the user side, whenever I test the form on my website I receive a message describing what I just wrote, you can test it out yourself by checking the website at https://mockumentary.xyz/
Has anyone else had experience with integrating forms in a YAML-based Netlify site? Any tips or advice would be greatly appreciated!
Thanks in advance for your help.
Best,
Mattia
@mattiamuravannuzzi I can’t comment regarding what you’re doing with YAML, that seems extremely project specific.
Netlify Forms only requires a HTML form to be detected in your build output, and for submissions to be a valid POST to a static route of your site.
You’ve likely already read it, but the Netlify Forms documentation is here:
Getting Netlify Forms working with Next can be a little trickier as you can’t POST to routes handled by Next.
Netlify have an explanation/demo here:
https://nextjs-platform-starter.netlify.app/classics
You can see the source code for it here:
https://github.com/netlify-templates/next-platform-starter/blob/main/components/feedback-form.jsx
