Hello!
I’m about to finish this and I found an odd obstacle any input will be greatly appreciated.
my domain (here in netlify): www.tetrabids.com
issue:
I’m using svelte with routify for a small and simple landing page, everything working on local and start checking that everything works in netlify but it seems that I have an issue with components rendering (for half a second in most cases) when they are not suppose to.
<svelte:window bind:innerWidth={windowsWidth} />
this appears to be the problem, this is a special tag that handles reactively the width of the screen, is works by putting it in the first line of the dom and it does the rest, thing that does in local, but after deployed I believe it gets stripped out or moved and causes that some conditionals are trigger before this is resolve (*just a guess could be anything else)
{#if windowsWidth > maxWidthTablet && windowsWidth != undefined}
<div class="col-2">
<img
class="slide-in-right"
src="./images/laptop.svg"
alt="Laptop with code on the screen"
</div>
{/if}
this for example, I tried to move things around and it keep happening now from mobile, any idea would be great, my guess on netlify doing something is over that it works in local as it should, and if the conditionals run over a non client variable (like directly true) this does not happens.
if anyone can check over this would be great
